tootall
| posted on 7/6/08 at 05:20 PM |
resistors??
hi there im wiring a gsxr 1000 k4 and it needs a 100 ohm resistor in one of the start wires from ignition i have the the resistor but does it have a
flow side a in or out side?
some people dream of sucsess, others just get on and do it !!
| posted on 7/6/08 at 05:22 PM |
No - a resistor is a static device that doesn't care which way round it's wired. The only concern is whether there are special physical
concerns - connectors, whatever.
tootall
| posted on 7/6/08 at 05:43 PM |
thank you thats a great help ill solder it in and see if it works. thought id better ask just incase i get it wrong
| posted on 7/6/08 at 09:07 PM |
resistors are passive non-directional devices. only thinkg you need to worry about is power rating.
