FlansS14
| posted on 9/7/08 at 06:58 PM |
Sensor imput 6.25v, how does that work!
I have a lotue elise stack dash to wire in. i have the plug diagram which is self explanatory BUT one pin says
sensor supply (regulated +V) 6.25 volts.
how do i do that with a 12v supply :s
help
Why didn't i just make it simple!
matt_claydon
| posted on 9/7/08 at 07:03 PM |
I would have thought it's an output to a sensor, not an input.
[Edited on 9/7/08 by matt_claydon]
tks
| posted on 9/7/08 at 07:47 PM |
yupsz an supply is an output.. else you woud need allot more info..
its to connect some kind of sensor to..
Tks
FlansS14
| posted on 9/7/08 at 09:40 PM |
that would make more sence
wonder which ones, could it be spedo or there is a cat overheating warning sensor on the elise.
| posted on 10/7/08 at 09:45 AM |
you have to supply more detials than that.
twat sensor is it by the way?
for example a hall effect sensor, as used for speedo, would have a voltage supply around the voltage you state.
FlansS14
| posted on 10/7/08 at 10:47 PM |
thats what i thought! i just have a print out of what pin goes to what and this is one or them. ill findd the pin list and post that up
martyn_16v
| posted on 14/7/08 at 09:31 AM |
Probably the throttle position sensor.
