Author: Subject: Electric Reverse
Davey D
posted on 15/7/08 at 09:05 AM Reply With Quote
Electric Reverse
Ive come to the last bit of wiring now which is my electric Reverse using a modified starter motor.
The plan is to wire it via a relay which is triggered by the Gearbox Neutral light ( so that i can only reverse when the car is in neutral )
What im wondering is what size fuse, and relay should i get that will handle the current draw from the motor?
Looking in the Durite Catalogue:
Standard relays take about 30A, Heavy duty around 70A, and Extra Heavy Duty take 100A
What should my choice be? Extra heavy duty relay, with a fuse around 60A ?
Paul TigerB6
posted on 15/7/08 at 09:17 AM Reply With Quote
Someone may correct me but i am sure you need a standard heavy duty battery cable for the main feed to the starter motor and then a switched feed to the solenoid, so it wont be that high an ampage running through the relay - same as you would have through the ignition switch when turning the key.
Mr Whippy
posted on 15/7/08 at 09:21 AM Reply With Quote
Why not use an unmodified starter motor as they tend to come with the solenoid already attached
Starter motors consume huge amounts of electricty, especially during the first microseconds when they have to build up their magnetic field. If you're pulsing the reverse button it'll continuously be doing this- big current!!
you have two options: go super high duty so it'll never go wrong or use a moderately high rated fuse, cable, relay etc etc and be prepared to replace them with higher rated items as / when they burn out until you find the right combination
Howlor
posted on 15/7/08 at 09:23 AM Reply With Quote
A selection of tea spoons in your pocket may be useful to put across the terminals!
Mr Whippy
posted on 15/7/08 at 09:47 AM Reply With Quote
I use to drive an old double decker that had to be started by sticking my house key across the starter motor terminals due to the starter switch not working and the engine constantly stalling when cold, I’d get right funny looks from passengers
Howlor
nitram38
posted on 15/7/08 at 10:41 AM Reply With Quote
You have two wires to your starter?
One is the main current from the battery and a smaller wire from your ignition key (start postion).
You either have a solenoid starter where the smaller wire goes or a seperate solenoid for the main current lead.
If you got it off a car, then go have a look at another one to find out!
Davey D
posted on 15/7/08 at 11:07 AM Reply With Quote
It is just the motor in a custom casing with a sliding gear that engages with a gear between the prop, and diff. It is From MNR.
It has just 1 terminal where you connect the +ve, and then it grounds through the casing where it bolts to the chassis.
I think ill just get some heavy gauge cable and the highest current rated relay i can get hold of, then a range of fuses to test, and stick with lowest power one that doesnt go pop
Howlor
posted on 15/7/08 at 12:31 PM Reply With Quote
How about something like this?
Linky
Davey D
posted on 15/7/08 at 01:07 PM Reply With Quote
All i was basically asking was how much current will it draw when im reversing... not how to wire it up
Fatgadget
posted on 15/7/08 at 01:25 PM Reply With Quote
Linky
LOL. Cant get better than tried and tested old not to mention simple solutions to seemingly complicated problems.!
Fatgadget
posted on 15/7/08 at 01:29 PM Reply With Quote
How about asking MNR? Surely they must of tested it and compiled some relevant data before putting the product on the market ??
Howlor
posted on 15/7/08 at 01:40 PM Reply With Quote
Doing some quick research would suggest that you could draw 150A on initial start up dependent on what rating it is and the load upon it. This would burn out the contacts on the 100A relay fairly quickly I would have thought.
rf900rush
posted on 15/7/08 at 04:51 PM Reply With Quote
Hi
The motor could pull 250amps + if loaded.
ie up a kerb/steep incline.
The Pre-engage soleniod will not change from no load to stalled.
If you are using your switch/relay to turn on the starter motor's pre-engage solenoid then a 30amp relay should be ok but 70amp will be better.
Bigger = better, and 70amp car relays are not that much bigger.
If switching the motor directly then expect 250amp + for a car starter motor.
[Edited on 15/7/08 by rf900rush]
