Author: Subject: Micra Radiator
posted on 17/12/03 at 09:19 PM Reply With Quote
Micra Radiator
I am integrating a Fireblade Engine with a Micra Radiator and have a few questions regarding coupling up:
The Radiator has a built in thermostat? or Switch?
The Engine has a built in thermostat.
Should I connect both the Engine 'stat (to temperature clock. Then the Radiator Switch (?) in series to the fan?
Basically what I am asking is: is the Radiator widjet a Switch or a Thermostat?
Any help would be appreciated!
givemethebighammer
posted on 17/12/03 at 10:11 PM Reply With Quote
Fan switch as far as I can tell. Its wired to the fan attached to the back of the rad anyway. (Well mine is)
posted on 18/12/03 at 12:28 AM Reply With Quote
The radiator should have a thermostatic switch. Is the one on the engine used as a water temp gauge sender on the bike? it is on my old 600 and is wired seperate from the rad switch.
yours, Pete.
posted on 28/12/03 at 03:54 AM Reply With Quote
Thanks...
so much!!!
Will use the thermostat from the thermostat housing block then...
Thanks again!
