scudderfish
| posted on 30/8/08 at 08:51 AM |
Smoothing 12v
I've bought one of these
http://www.viglen.co.uk/viglen/Products_Services/Product_Range/Product_file.aspx?Type_Info=Description&eCode=XUBUMPCL&Type=Desktops&GUID=
to stick in my car for various control and logging tasks. It requires a 3A 12v supply and I'm sure if I connect it directly to the car the
magic smoke will soon be let out of something important inside. Does anyone have any advice on how best to feed a nice smooth 12v into it?
| posted on 30/8/08 at 10:08 AM |
You need to find out if it uses the raw 12v for any internal circuits. Many of these micro PC use an internal switching regulator to reduce the 12v
down to 5v and 3.3v and can be used from an unregulated 12v source.
If this does need a regulated 12v, then I don't know of any off-the-shelf solutions
ReMan
| posted on 30/8/08 at 10:09 AM |
You need to check the tech data, for it. You will probably find that it gives a voltage range around 10-15v in which case the car will be fine.
Failing that a simple voltage regulator chip and a couple of other components should be only a few quid to build if it is vital that it is exactly 12v
| posted on 30/8/08 at 10:20 AM |
Unfortunately it's not that simple. A simple linear regulator can only reduce voltage, and needs some overhead to work properly. For the
regulated 12v, you may need 13-14 volts which may be ok when the engine is running, but once it's stopped, and especially during cranking the
regulator will drop out of regulation. It will also needs to be capable of 3amps which rules out 7812 and LM317T solutions.
The ideal solution is a SEPIC switcher which can reduce and increase voltages, but as I say I don;t know or any off the shelf solutions.
ReMan
| posted on 30/8/08 at 11:03 AM |
I am fairly sure you can get 5A voltage regs?
I don't know what he spec for the regulator is, but even at standstill a fully charged battery is at least 12.5 volts anyway, so I don't
see why it wouldnt work.
As you say at cranking, it will drop considerably, but it would probably also drop below that of the input of a dc to dc converter to maintain the
output too?
So unless a completely independant supply , similar to a UPS is used with internal battery, which in itself is compicated and expensinve, then surelya
a simpler solution is better.
As said, it may be that the input voltage of the PC is tolerant of car battery voltage variation anyway?
novacaine
| posted on 30/8/08 at 11:39 AM |
its not an elegant solution but how about getting one of those 240V inverters, and a regulated 12v power supply (maplin do a suitable one) and install
that,
not elegant but it does the job
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
scudderfish
| posted on 30/8/08 at 02:08 PM |
There is the LM138 which is good for 5A http://www.national.com/mpf/LM/LM138.html, would that be a suitable starting point?
Maplins do a laptop PSU which would do, but at £30 when the PC only cost me £80 seems a bit steep.
scudderfish
| posted on 30/8/08 at 02:11 PM |
Ouch, that 5A regulator is circa $40!
scudderfish
| posted on 3/9/08 at 01:58 PM |
I think I've found a solution. The Eee 901 laptop uses 3A @ 12v so I just bought a cigarette lighter adaptor for it from eBay for £6 delivered.
I'll crack it open and wire it permanently into the car. Fingers crossed, the smoke will stay in.
