| posted on 11/1/04 at 01:33 AM |
Micra Radiator Thermo switch power
Just a quick whilst I can't sleep for thinking about it...
On a BEC we've used a Micra Radiator - the radiator switch uses the fused link from battery so is allowed to run when engine stopped.
My question is - what power does the Micra Fan use... and does it use a relay when in situ in the Micra?
If it does use a relay I'll need to put another relay in!
| posted on 11/1/04 at 02:07 AM |
id be very suprised if it needed a relay, cant see it using that much power. my polo one certainly didnt have a relay, plus when i tested it over a
battery it barely sparked, indicating not much current. HTH...
zetec
| posted on 11/1/04 at 10:16 AM |
Not sure about Micra but I suspect most do run with a relay as ECU triggered. For the small time it takes to install a relay I would use one just to
save wear on the sensor contacts. The running current might be low but suspect the start up draw is quite high.
| posted on 11/1/04 at 02:46 PM |
i suppose you're right, its only a few quid and a few minutes.
didnt know some were ECU triggered, that must be a thing from new engines i guess. my polo and sierra barely knew what a chip was!
on my polo however, it definately was a simple circuit as the wire from the radiator mounted thermostat goes a foot thru the loom to the fan, then
straight to earth.
[Edited on 11/1/04 by JoelP]
