bob tatt
| posted on 23/10/08 at 04:59 PM |
busa speedo help needed
right here goes i hope some one on here can help, in the prosess of fitting the busa engine and clocks really want to keep these as i really like
them and they read all the way to 220 not that it will ever get near that one problem the speed pickup is on the end of the output shaft and this is
no longer there due to the prop has anyone done this conversion and how do i get a new speedo pulse back to the clocks. there will be a speedo healer
on when finished my thought was to use some magnets on the prop and try to take the discrepencies out with that. many thanks in advance rob
iiyama
| posted on 23/10/08 at 09:25 PM |
Use the existing pickup mounted so the flat edge is point near to the 4 bolts for the drive shaft. The speedo healer will sort out the rest when you
calibrate it
