Author: Subject: Number plate light problem!
prawnabie
posted on 2/11/08 at 07:38 PM Reply With Quote
Hi Guys
I have just fitted a new "mini" type numberplate light to my locost.
As per usual, the "base" of the numberplate light is earthed and the live part is seperated by a rubber shim.
This is all hunkydory until I insert the bulbs, then the whole assembly becomes earthed. There are two bulbs in the light and this happens with either bulb it.
Is this right because it is driving me mad!
Shaun
blakep82
posted on 2/11/08 at 07:43 PM Reply With Quote
how are you measuring it? if you're putting a multi meter against the body (of the light, or the car, or earth lead, whatever) and the other terminal agaisn't the live wire, when the bulb's in, then its correct
________________________
Paul (Notts)
The bulb will connect the live supply to the earth so that it lights up!
Paul
posted on 2/11/08 at 08:21 PM Reply With Quote
^^^ wot they say.
if you are measureing resistance, even a 6 W ublb would be about 2 ohm - that depending on your meter will look more or less like a short.
if the lamp hourins is open circuit before you insert the lamp and when you insert the lamp, the two contacts contact t he bulb correctly, it soulnds like it is ok.
if you are worried, temporarily fit a small A fuse between the wire and lamp., a cheap way is to take a mains cable, strip it down and take one or two filaments from the wire - that will act as fuse.
posted on 2/11/08 at 10:09 PM Reply With Quote
Wot they said.
You could use a fuse.
Personally I'd just "flick" the feed +ve wire onto the +ve supply of the car battery and see what happens. You should get a little spark (the bulb will pull a little bit of current). You'll know if you've got a short because you'll get a flipping big arc!!!
Crude but effective....
prawnabie
posted on 2/11/08 at 10:28 PM Reply With Quote
Thanks guys, just confused me - sorted now!
Shaun
