Hi people,
I have a twin master cylinder pedal box with a balance bar, cortina front brakes and an english rear axle with drums fitted to my Locost chassis. Do I
need a servo?
I have driven cars without in the past and it wasn't so bad, but does anyone have any personal experience of a similar setup and
recommendations?
Cheers.
No, you don't.
I've not seen any twin master, cylinder balance bar set-up that had one. I'm not sure how it could be done; Would it be possible with a
remote servo?
Servo's on 7 type cars are only for girls
No you don't need one
Originally posted by adithorp
No, you don't. I've not seen any twin master, cylinder balance bar set-up that had one. I'm not sure how it could be done; Would it be possible with a remote servo?
No light car needs a servo.
Servo's on 7 type cars are only for girls![]()
Servo would do you more harm than good if you think about it, lightweight car, less brake feel, wet road , all wheels lock = under a truck.
Bob
Originally posted by CaptainWow
Hi people,
I have a twin master cylinder pedal box with a balance bar, cortina front brakes and an english rear axle with drums fitted to my Locost chassis. Do I need a servo?
I have driven cars without in the past and it wasn't so bad, but does anyone have any personal experience of a similar setup and recommendations?
Cheers.
Cool, I will fettle my pad, disc and shoe choices when I get the thing on the road, thanks for the advice guys. Will make my build a little easier
Cheers.
I built my car from scratch, Rover V8, polo pedals, Shogun servo and master cylinder, granada mk2 front uprights and calipers with vented discs, 2.8 capri axle with xr3i front calipers on the axle and vented discs- calipers were modified to accept cortina handbrake cable working with avenger ratchet handbrake which has both hydraulic cylinder in the feed to rear calipers and handbrake cable connection, the pedals are mounted pendulum style, they have the same travel as in a polo (1984 model) and as such don't travel very far, the servo and master cylinder are mounted pointing rearward so I've a hump in the dash to permit this and instruments mounted in the cetre of the dash, needless to say the barking is immense, a reasonable amount of force is required upon the pedal, it's far from mega light as in most modern cars, I can easilly lock up at 50 mph if I try, I find the huge braking power in reserve makes driving it very relaxing, it's certainly comparable with my daily driver golf GT Tdi 130 with aftermarket grooved and vented discs, Having driven polo's without servo's in my teens I would advise any locost builder to fit them however I do feel sierra/cortina master cyl/servo certainly do lack feel, The shogun set up cost £25 including delivery from the nations favourite auction site :-)
Welcome. Just one thing, its worth noting the date of the original post as this is a 2 year old thread.
