Hi, looking for a couple of air filters that will connect to 2" pipe, (preferably with a inlet for the rocker vent pipe to fit to), but not
essential. Anybody know where I could pick some up, for locost money,
. Cheers Ray
THIS Type of thing? you could make up a steel connector with a tee off for the rocker cover.
R1pete the ones i need are for fitting to, two 4 pot 1.8 ltr turbo diesels, (should have put that on the post), so I dont think they would flow enough
air, although could be proved wrong. Price sounds good though. I have already started to make up two 2" steel pipes with take of's for the
rocker vents. Cheers Ray
[Edited on 20-12-09 by Chippy]
