What would be the force required to sheer a 4 mm socket screw (aka grub screw), tensile strength 14.9.
(I need to see your working out)
in the application below.
there is a rod that is 15 mm diameter (L2) that is iniside a fixed steel tube.
A 4 mm socket screw is fitted between them.
At the other end is a lever, L1, that is 150 mm long.
A twisting force is applied to L1 of 100 kgf, so I reckon force across the socket screw is:
100 x 150 / 7.5 = 2000 kgf
This is applied across the 4 mm socket screw - will the socket screw sheer or not?
(cross section of m4 socket screw is 8.4 mm2)
sheer force?
[Edited on 18/10/10 by 02GF74]
If the bolt in in pure shear and there is no clamping friction to also resist the shear then the shear strength is 0.6 of the tensile strength
Yeild strength of a 12.9 bolt is 1100MPa or 1100N/mm^2, you should be able to work it out from there
But if not, root diameter of an M4 is 3.141mm, so thats a CSA of 7.7mm^2 so a yeild strength of 8470N or a shear strength of 5082N (518Kg)
Assuming single shear, if its double shear, double the force
Or if i read the whole thing it would help....
The shear info still stands though. Work in Mpa if you can, its easier
[Edited on 18/10/10 by flak monkey]
errrm yeah .... Think so .....
can you also explain E=MC^2
Easy.....4 white knuckles what else
Sorry if i'm being thick but Wouldn't the Hexagon in the middle of the screw 'give out first' ?
good observation, you get a gold star - yes it would but it depends on there the hexagonal hollow is in relation to the sheer (or is it shear?) plane
i.e. using a long socket screw with the hollow part sticking out.
[Edited on 19/10/10 by 02GF74]
