Is there ford mechanic/engineer out there/on here?
Whilst giving my car (mondeo 2.2 tdci st 56 reg ) a service, I went to change my filter, and it was tight as a nun's
Then this happened
[img]
[/img]
The plastic filter cap has a plastic nut, which cracked and leaked out oil. Managed to get the old one off ( had to use a hammer and chisel as the
plastic nut 35mm just fell apart )
Think fords must have used an air gun to do it up.
Can these be bought on there own or is it a new oil pump..
And to top it off, when I drain the oil from the sump into my nice new bucket, it had a hole so there is oil over the drive, at least I cant move the
car so the wife cant see the massive oil slick
[Edited on 7/11/10 by grusks2]
Whoops, they are only supposed to be tightened to about 20NM or so
I work for one of the major breakdown companies and I have known these be stolen in the night, presumably by people in a similar position to you! Yes they are available on their own but you may have to order it I don`t think they are a stock item.
Is this the part ??
Also very worryingly, i was going to do an ooil change on my 2008 2.0 TDCI tomorrow !!
BRAND NEW OIL FILTER CAP BOWL FORD MONDEO 2000-2007 on eBay (end time 26-Nov-10 20:18:11 GMT)
Or
OIL FILTER CAP BOWL MONDEO DURATORQ 2000-2007 DURATORQ on eBay (end time 02-Dec-10 08:30:56 GMT)
and there in Essex !!
[Edited on 7/11/10 by steve m]
Gunk do some great driveway cleaner you can get from halfrauds. Wroked very well when this happened:
Dad never knew
I now always use a big 24" x 24" deep sided tray, under the car, with the oil catch tank sitting inside, usually bought from garden
centres
As i have had similar problems on an oil change !!
Originally posted by steve m
Is this the part ??
BRAND NEW OIL FILTER CAP BOWL FORD MONDEO 2000-2007 on eBay (end time 26-Nov-10 20:18:11 GMT)![]()
Or
OIL FILTER CAP BOWL MONDEO DURATORQ 2000-2007 DURATORQ on eBay (end time 02-Dec-10 08:30:56 GMT)![]()
