anyone know where to get the foam stuff and the plaster that folk use when theyre designing bodywork?
http://www.antenocitisworkshop.com/news/2010/11/blue-foam-pink-foam-foamboard-and-styrofoam/
kingspan celotex from builders merchants
I use this stuff - unlike the builders foam it can be fibreglass'd and filled .
If you have any companies nearby that deal with refridgeration/insulated vans or similar they may be able to supply you with polyurethane insulation,
or put you onto a supplier. You can also "blow" your own, in usefull shapes if you can get the raw materials to mix.
The foam is classified by density, I used a 32 kg per cubic metre density, heavier would be better.
Fred W B
