The situation is, I've bought a US-made vehicle and want to fit a 're-moveable' tow bar. The problem is that the only one that I can
find is in the U.S. and is therefore not EU type-approved. What's the worst that could happen? Obviously, I'd not dream of exceeding
recommended loads etc.
TC
Check the US one has a 50mm ball and not 2". Imho, if the towbar looks strong enough, it will be ok.
What vehicle is it?
I think you have to be prepared if something goes wrong to accept that you might have reduced or no insurance cover.
I think you are unlikely to be prosecuted though.
IMHO of course and I may be wrong
What vehicle is it?
I suspect it will depending on when it was IVA'd/SVA'd on import. As tow hitches have been type approved after some date (forget what) but
if the vehicle pre-dates hitch type approval will not be needed.
Probably the safest thing to do is write to VOSA and ask what the deal is if you want to avoid complications with insurance companies. I have found
VOSA very good on the phone (unlike the DVLA) you can talk to an expert that knows the rules and how they are applied.
Originally posted by Bluemoon
I suspect it will depending on when it was IVA'd/SVA'd on import. As tow hitches have been type approved after some date (forget what) but if the vehicle pre-dates hitch type approval will not be needed.
Probably the safest thing to do is write to VOSA and ask what the deal is if you want to avoid complications with insurance companies. I have found VOSA very good on the phone (unlike the DVLA) you can talk to an expert that knows the rules and how they are applied.
I'm pretty sure that if the vehicle hasn't got EU type approval, the towbar doesn't need it either. The bar I fitted to my Connect had type approval for about three months. Then the sticker fell off!
It was made in the US and that's where it was popular but its a UK car, not a grey import. The type approval rules seem to count from 1998 and the car is a 2001 so it looks like I'm a bit screwed.
It is illegal to drill holes in the body, or chassis members, to fit tow bars.
Pretty sure this wasn't asked in the question and that the statement needs clarificationt to be accurate.
Davie
when i went for my last iva there was an american truck there that failed iva because its tow bar didnt have type approval. the guy removed it in the carpark and put in for a retest 10 mins later with it sitting in the bed of the truck
Its not illegal to drill holes to fit a towbar. I've fitted several EU Type approved towbars in the past 18 months and at least three needed holes drilling. Probably more than three!
Davie
"it came with it" is the answer methinks.....
I suspect type approval just means it fits to the existing fixings (and yes, they often need the attention of a drill or 1" holesaw) but then
again I tend not to worry too much about these things, life is too short
http://www.towsure.com/search/Honda+civic+coupe
Is this the bar you want ?
Is this not what you want?
http://www.detachabletowbars.com/civic-coupe-2003-2006-detachable-tow-bar.html
Witter bar for 2003-2006 civic coupe
Regards
Hugh
Regards
Hugh
No problem - I had a non detachable on my coupe and was always bashing my shins on it when getting stuff in and out of the boot!
Regards
Hugh
