engine rebuild
whitstella - 16/3/12 at 07:00 PM
hi
for a while now i have wanted to rebuild an engine (for some reason) i like to know how things work, so i was just wondering if there was any engine which is more simple to rebuild. i would like something i could fit in a kit car so mx5, redtop, k series. i am a maintenace engineer so it might help.
are there any others.
and other people thoughts on rebuild would be good.
cheers steve
blakep82 - 16/3/12 at 07:06 PM
zetec is probably the easiest/cheapest to get hold of, cheapest on parts etc. thats where i'd start, if i could afford to
omega0684 - 16/3/12 at 07:51 PM
pinto, dead easy!
johnemms - 16/3/12 at 08:48 PM
I had the head re-worked skimmed - valves cut & ground & assembled.
I had the block bored out & they offered to assemble the pistons/crank big ends/crankshaft&bearings.
(also ground the crank & lightened the flywheel)
That broke the back of the job
It was'nt expensive and made me feel better knowing it was all done right... !!
