Hi all,
I have not got the most tip top ears in the world as I used to build big cars stereos for a living a few years back and love a live concert or gig
with big bass every now and then but my tinnitus is getting LOUD!!!
I think its due to the striker. I dont have a window screen and even at 30mph the wind noise in my ears is quite a lot. I have been wearing ear plugs
or a bash hat for prolonged driving or faster journeys but I still think its getting worse.
I remember a saying that if the noise lasts longer than the exposure then your causing trouble. Well I can always hear it if I stop and concentrate
but its disrupting and almst disorientating now.
I think ill have go and see my doctor, although he is useless and will blame the car as soon as he knows what I get up to without offering any
help.
Have you guys got any help advice?
Oh and I am not going deaf, thats something different. My hearing, I think, is very good when above the noise. Crisp, with good direction and depth.
I have it a bit....it's annoying because i cannot make out conversations in a noisy environment....i.e. busy pub etc....
I don't think it's reversible.....however it doesn't really bother me now unless i concentrate on it....
Wear plugs if you think you are at risk.....
Welcome to the club, doctor will not do anything have a look at the tinnitus association web site.
I'm afraid you will have to do what the rest of us do and ignore it.
Can run in families My Gran had it, My mum has it, so do her brothers, I have it and my son has it!!
You need to wear some ear plugs - get a big bag of foam plugs from screwfix or somewhere.
I read an article in a bike magazine recently that was about ear defence - the wind noise alone when wearing a bike helmet will cause more hearing
damage than the noise of the engine. It's not worth damaging your hearing any further for the sake of a few pence worth of orange foam!
I find that they wipe out the wind noise almost completely when not wearing a helmet but you can still hear the exhaust note nicely.
I am sorry to say
My Doctor told me there is no cure for tinnitus i have it in my left ear but some times my right ear joins in when i am in a quiet place
They hisssss all the time
I always use a helmet in the kitcar
Jacko
What kind of ear plugs are you using? if its those cheap roll up foamy things bin them and get some proper ones. I have got etymotic ones and they give a good amount of noise reduction in windy conditions. Usually I wear my lid and ear plugs. The real advantage of the et ones is that they let important sounds through so you are aware of your surroundings.
Speak up I can't hear you over this damned hissing noise
I am an audiologist. Your tinnitus can be temporary, or permanent. There is no cure, unless it is caused by medication (cancer drugs tend to encourage
it). Protect the hearing you have, because noise exposure is known to cause permanent damage. The little foam things from Boots are fine, but
don't expect to be able to converse easily while you are wearing them.
I recommend some custom ones from your audiologist. They are kind of expensive, but necessary for musicians and talkative car mechanics and sports car
drivers.
ps Etymotic is an excellent company.
[Edited on 21/8/12 by RK]
I have it mildly at 32, from power tools. Take it seriously kids, its something you dont think about til its too late!
Cheers for the feed back gents. Some interseting points.
Big Vee: I wondered if it had herditory roots, my mum has very bad ears. They are swallen including inside, I hope I dont get that.
Stevie: I do wear ear plugs, just not all the time. I think that will change. When I wear a helmet I normally have plugs to because it feels like its
resonating in the helmet.
ASHG: I use the cheap orange memory foam types. 50 disposable pairs for £10 or something.
RK: I think I may invest in some smart ones if they make a genuine difference. Whats sort of life usage do they last for?
When people are wearing plugs, especially with a bash hat, do you feel disconnected from your car? I kind of like hearing out for worring knocks or
rattles!! On the otherside of things it is nice driving blissfully without worring about "what was that?!"
I take it a full screen will not help unless it wraps around?
Also I think its more of SPL rather than noise, thats the problem with wind noise over exhaust noise. It just blasts my drums.
Any other thoughts,
I nearly allways wear ear plugs when out in my Fury - usually the foam type with a cord joining them , these can be wrapped round the gear lever so they dont go walkabouts and are allways there .
Tinnitus is a swine, probably cause of mine was a viral infection that made me partially deaf for two months rather than the fairly
massive ammount of noise I have been exposed to.
However serious ringing in the ears can also be caused by wax build up. Ear wax can get as hard as cured epoxy resin.
[Edited on 21/8/12 by britishtrident]
Yeah it doesn't really go away, mine hasn't after about 10 years (I'm 32... )
However I have found spending time in quiet helps, like one day a week in pretty much complete silence.
Originally posted by RK
I am an audiologist. Your tinnitus can be temporary, or permanent. There is no cure, unless it is caused by medication (cancer drugs tend to encourage it). Protect the hearing you have, because noise exposure is known to cause permanent damage. The little foam things from Boots are fine, but don't expect to be able to converse easily while you are wearing them.
I recommend some custom ones from your audiologist. They are kind of expensive, but necessary for musicians and talkative car mechanics and sports car drivers.
Custom plugs will last for two years minimum, unless your ears grow at an abnormal rate. Expect longer. The diaphrams (noise filters) inside can be
replaced with differing levels of attenuation.
Ignoring other causes of tinnitus (dislocated stapes, etc)...
The helmet will go a long ways to cutting down noise too, but the plugs are a good investment, even if they are the 25p versions. The amount of
attenuation they provide is not that important (anything is better than nothing), rather the areas of frequency range. Foam plugs attenuate the higher
pitches too much, making conversation difficult, making everything dull sounding.
Finally, you have to insert the foam ones properly: squish down with clean hands, and hold in place for TWO minutes, so they expand in the right place
in your canal. Otherwise, they do bugger all (technical term). This is an advantage to the custom ones: they always go into the same place, and you
can easily converse whilst wearing them because things sound normal.
I have had a similar problem with my hearing. It got so bad I could hardly hear the rover v8, the cure was suprisingly easy.
I fitted some straight through exhausts and now I can I can hear it perfectly well (upto 2 miles away)
Ive had it for about 4 years it does come and go to diffrent levels, some people say the bones in the inner ear can be manipulated to reduce it, also causes of the tinetus can be extreme exertion of the neck( riding sports bikes) whiplash and high levels of caffeine, along with the usual industrial noises etc..
I'd be wary of saying "tinnitus doesn't go". There are multiple reversible causes of tinnitus. And other causes which are not so
benign. So it's silly to ignore it.
including..........
Otosclerosis
Acoustic Neuroma
Wax
Eustachian Tube Dysfunction
and of course straightforward plain vanilla tinnitus
The reason to be cautious is that most people have some history of loud noise exposure. Most people have either gone to a few gigs, clubs or gone
shooting, tinkered with cars etc etc. So you can fob people off by saying it's benign tinnitus (on account of a little exposure to loud noise
that all people have) but it's bad medicine. It's a bit like the opposite of when you get your glasses and Mr/Mrs Specsavers flogs you
unecessary lens coverings by asking if you ever drive at night or use a computer (anti-glare) or go out in the sun (UV). Unless you're a
technophobic bus-loving vampire you probably will
But it makes it look like they're "assessing" you!
The way I look at tinnitus is this- if it's straightforward tinnitus it's not going to get better, it's just going to stay the same or
get worse. So it makes sense to have looked into it from the beginning to made sure it's none of the above.
The bill is in the post
what i remember from my time studying it, there are different causes and a number of different types, some can be help by medication but that is the
minority.
if you are finding that driving you car is bringing it on, and/or making it worse, you have to invest in ear protection and if that does not help
seriously consider not driving that car. if you continue, it will come to a point that your life will be a total misery, especailly when trying to
sleep at night since there is lower background noise amking the tinnitus more noticeable. those that have it really bad need to wear a masker - a
hearing aid type device - that plays noise in order to cover up the tinititus.
Originally posted by ashg..I have got etymotic ones and ...
Originally posted by BenB
I'd be wary of saying "tinnitus doesn't go". There are multiple reversible causes of tinnitus. And other causes which are not so benign. So it's silly to ignore it.
including..........
Otosclerosis
Acoustic Neuroma
Wax
The reason to be cautious is that most people have some history of loud noise exposure. Most people have either gone to a few gigs, clubs or gone shooting, tinkered with cars etc etc. So you can fob people off by saying it's benign tinnitus (on account of a little exposure to loud noise that all people have) but it's bad medicine. It's a bit like the opposite of when you get your glasses and Mr/Mrs Specsavers flogs you unecessary lens coverings by asking if you ever drive at night or use a computer (anti-glare) or go out in the sun (UV). Unless you're a technophobic bus-loving vampire you probably willBut it makes it look like they're "assessing" you!
The way I look at tinnitus is this- if it's straightforward tinnitus it's not going to get better, it's just going to stay the same or get worse. So it makes sense to have looked into it from the beginning to made sure it's none of the above.
The bill is in the post![]()
regardless of what has been said by others i wouldnt go back to foamies after using the etymotics
