Hi guys , I am hoping the collective can offer a solution to a problem I have with my Primera's wipers.
The problem is when I turn on the wipers they work as they should on both speed's BUT, they wont turn off again.
I can make them turn off by flicking the ignition switch of and on again then park them with the nudge facility.
I can see one day me flicking the ignition off and the steering lock dropping in...........PANIC!
I put it to the learned collective
Regards Denis.
probably a relay
If its a 2002 onwards it could be the wiper motor as it was quite a common problem when i worked at nissan...l
wiper motor internal fault
I had a similar problem with the wipers on my Fury - turned out to be the park switch on the motor .
Thanks fella's
I will try to find a second hand motor.
Denis.
