Help!!!!!! I'm driving from Plymouth to Cardiff and by Garmin can't find any addresses in Wales. It doesn't know where Cardiff is
although I can get there no problem. I won't be able to find the address in cardiff I am trying to reach. Is this a country problem. Will it come
right when the stupid machine recognises that I am in wales on the M4. Is there something I can reset.
I'm sure I have UK maps but it seems only to recognise England addresses. Is thes because I am in england at the moment?
Hi click on the Union Jack and you then have the option to change country, change to Wales and you should be ok.
mine a fair bit older, but as above, when you search by address, first thing mine asks is which country i'm looking for, press E it comes up with
England, type S it comes up with Scotland, never tried Wales or Ireland yet.
suspect it comes under user error rather than stupid machine
Brilliant. Success. Safely and easily found the house.
Easy when you know how. Thanks again for the help. I'm most grateful for the instant reply. The LB massive rule!
[Edited on 26/8/12 by Dusty]
