Has anyone built a duratec striker yet? I know there are a few fury's but I'm trying to work out if the bonnet will clear and what i may
need in the way of shortened sump and rocker cover if I went this route.
Many thanks.
Ben.
iirc there was a lad called Darren Cudd who was building one ?
He used to have a big horsepower cossie in a Westfield and then sold that and started building the Striker with a nice spec Duratech.
Also thought Mel at RAW had built a Striker with a big horsepower Duratech in it as a development car and it was at one of the shows ?
It was in a Black bodied Striker iirc
Link
http://home2.btconnect.com/rawstrikernorth/strikernoble.html
Looks like the bonnet has been made different to accommodate the engine,
Higher and squarer edges,
Member seeing this car at the show awesome kind of made me like the strikers hence why I have one now,
Mines better of course
Sean
Ps got a k series in mine fits fine if you use as I have direct to head throttle bides this saves alot of room,
Thanks guys. I have seen the black car you are talking about. It was built by raw north, not Mel and also had a huge bonnet which i would like to
avoid. I know Martin at Raw did build a s2000 car but it was very tall and a lot of work. There current preference is for super charged zetecs but
I'm not a fan of the zetec.
If the duratec isn't going to work, any other ideas? Looking for something capable of at least 200 bhp and lighter the better. Quite happy to
give something different a go. So far i've had 4age, r1 and ford sigma.
ZZR 1400 or Tuned Busa ?
Remember having a chat with Mel and he said the Vauxhall XE will fit, Although i'm biased
To be fair the Duratech is pretty light though, but i'm not too sure how tall it is ?
It's a hard choice!
I've just managed to put a few pics of my old striker in my archive (only taken 6 years!). Can't work out how to put them in a post yet! It
started life with a 4age before the r1.
Looks like the supercharger gubbins sticks up higher than the rocker covers
This quote from the web site worried me though
Fondling Rob by appointment only
I'm building one, it will fit............will try and get some pictures up for you...
I've completely stripped mine down and rebuilt from chassis up. Had to make a few mods on the chassis to get it where I wanted it, but
there's plenty of headroom under the standard bonnet for it (well 5mm anyways......)
I took the opportunity to upgrade to the new look scuttle at the same time, the bonnet is the same height as the old version. any other info you need
just give me a shout
[Edited on 18/2/13 by clanger]
a few for you..............
gimme a shout if you need anymore?
Thanks for the pictures. looks good. I see it needed a little work around drivers footwell. which bellhousing and box are you using?
yeah had to take a small 5-8mm section of the footwell back a tad, does not affect the inside where the clutch is. I wanted to get it as far back as
possible. you could technically leave it and not bother with the footwell mod, but there's a possiblity of the fuel rail catching on the part
where the bonnet dips down to the nose cone and whatever induction setup up you chose. wnat to get mine all under the bonnet with no ugly cut-outs so
chose that way to do it.....
bell housing was from rallydesign
Thread revival. I'm doing similar, but mating the duratec to an mx5 mk3 box. The gerarbox fits well into the tunnell,but I could do with getting the bellhousing back another inch or so if possible. When you cut the notch out of the drivers footwell upright, did you just weld a patch in it to retain strength? I Was thinking about notching out both the driver and passengers side patching them and welding in another upright behind them to support. Not sure if that's overkill? Also not sure if I could just get away with removing the passenger side upright and welding another back in 40 or 50mm further out or if that would mess up how the loads are transferred through the frame. an extra 20 to 30mm clearance each side would make a huge difference
That'd be great thanks
Gavin
Not with the car at the minute but this shows the cutout
Footwell cut
I can get some more pictures next week without the engine if you want?
I have got clangers car/chassis now. I will try and get a picture of that mod and post it up for you next week. The car is still not finished yet but 1) I am fussy and 2) I have a business to run so little or no spare time!
Originally posted by CosKev3
Very nice car that will be![]()
I viewed it and sent him a deposit,he changed his mind the next day and refunded it![]()
When did you buy it?
Looking good.
Lynsey had done a lot of nice little mods to the chassis from what I remember
Thanks for the Pics, Really useful. Good luck with the build
