Hi all.
Not sure if this is possible or not. I have an old paj and it has a very old remote imob in it.
When I got the car i had two remote fobs. One is now completely humped and the other is on its way. Case is broken buttons starting to fail etc.
I cannot find this alarm anywhere to get new fobs,I dont need keys they are fine.
I was wondering is there a way to copy the signal from my, currently still working, remote and put them into another device?
It has 4 buttons but I only think 2 of them do anything.
[Edited on 15/3/13 by emsfactory]
Just ask your local Pikeys I'm sure they'll know a way
Found Universal Cloning Key Fob Remote Control RF for Garage Door Gate car Copy Code | eBay not sure if it's what you
need?
HTH
I suspect, no due to the algorithm inside the main control unit.
Speak to mitsubishi. They might be able to order a new one and code it for you.
Ha, yes they probably could!!
I saw those on ebay. Not sure if what i have is 433mhz. Probably is its pretty old. For a few quid may be worth a punt.
I'm fairly sure you can't copy the fob, but a decent car locksmith should be able to source a new fob and code it to the alarm.
I've used Eydens in Coventry a few times. If you take the car and the fob to them, they should be able to sort you out with a new fob. Or if
it's too far away perhaps a phone call for advice might be useful. As long as the aftermarket alarm is still a brand name I'd hope they
could do something for you.
As Mike says any decent alarm will be a rolling code. Each press of the button sends a different code, calculated through a complicated algorithm and
the alarm has the same algorithm to know what the next code in the sequence is.
If it's not got a rolling code, then it should be possible to get a new fob programmed BUT then it's hardly worth having on the car. Anyone
can record the code when you lock the car (bit of electronic knowledge and a trip to Maplins) and then replay the recorded signal back to the car once
you're out of sight... hey presto, your car's unlocked and the alarm is off!
What manufacturer made this alarm then? Give us some clues
You can often get new fobs from the major manufacturers, then there'll be some specific process for programming the new one in.
The transponder immobiliser I got, to add a fob, you have to program in all the ones that will be in use at the same time.
the fob says phoenix digital on it. I cant find a picture that looks like the fobs I have.
I am pretty sure they are more than 10 years old.
More looking possibly a pd175
I suspect it will depend a lot on which car it is.
On my Mondeo, I can self clone the fob to open the windows and doors.
However you cannot clone / programme them to turn off the imobiliser / security system. This can only be done at a Ford Main Stealer.
Key and programming for everything 3 years ago cost £170. NOT Cheap
Does it look like this?
back in the day my company used certain models of universal remotes to match to certain alarms.
i would suggest that if its not cat 1 alarm and a pajero buy a cheap alarm off of ebay for 30 quid and fit a new alarm with 2x new fobs. it will be
cheaper and sounds like easier.
i already have an alarm fitting guide posted up on this site. replacing a working alarm with another is about 2 hours work.
Take a picture of the fob with your camera and post it...
i would suggest that if its not cat 1 alarm and a pajero buy a cheap alarm off of ebay for 30 quid and fit a new alarm with 2x new fobs. it will be cheaper and sounds like easier.
fobs
alarmfob
I am assuming these are RF devices, you are going to need its frequency before you can copy one.
