Chaps
So I managed to punch a big hole in the block on my RPE Kawasaki zzr1100 motor in the back of my Radical. The good news (relatively) is that I have
another motor to install. The bad news is that there is what appears to be a fixing for a return line welded into the head. My question is, where
can I purchase this kind of fixing from? It measures 21.6 mm on the threaded section, which seemed a strange size to me...? Its just the weld in
part I need, leaving a male threaded section for the right angle fixing to fasten to.
I also need an adapter for the oil pressure sender, it's 17.7mm and 8.5mm respectively on each side of the adapter, any ideas where to get that
from too?
I will post some pics once I remember how to do that...
[Edited on 16/3/16 by carpmart]
Could do worse than talk to these guys linky
HTH.
Cheers, Pewe10
One of these for the cylinder head probably:
AN -10 (AN10 -10 JIC AN 10) Male Aluminium Weld On Fitting Round Base
And the second fixing is probably an M18x1.5 to -3 AN/JIC.
They look like standard Goodrich fittings.....
I agree with phelpsa, the cylinder head will be a JIC AN-10 (also called dash 10) male weld on and the sump fitting will be an M18x1.5 to JIC AN-3
male to male union (also called dash 3). They are religiously used with race teams.
http://atecautotechnic.co.uk/en/ will have what you need, I don't have a catalogue handy for part numbers but give them a call and they'll
be able to sort you out.
[Edited on 17/3/16 by Tatey]
Many thanks to all who replied and assisted with my questions..... I'm all sorted now!
