I'm after any ideas to remove a stuck front suspension arm.
The offside lower arm on my wife's Matiz needs replacing. I have already done the nearside, but the offside has been stuck. I've freed the
balljoint from the hub and released the arm from the anti-roll bar, but I can't release the arm from the car body.
There is a 5-sided cube, with the arm inserted through the open side, so that is the only access. The cube is approximately 2-1/2" on a side. The
end of the arm contains a bush, with a crush tube and a bolt through the box and crush tube into a welded nut on the other side. The arm/bush fills
the cube from side to side, sits around 1/4" from the back and has about 3/8" above and below.
At first I could not move it at all, but with much penetrating oil, time and effort, I eventually got it to start moving, but with great effort.
Having moved it a little, it is clear that the crush tube has corroded solidly onto the bolt and unscrewing it is bending the side of the cube and
threatening to push the crush tube through the metal.
Any ideas how to get it out?
Cut the bolt? With what?
Cut away the arm? And then what?
Burn away the rubber and hope that the heat releases the tube?
Is there enough room to get some parrot grips like
this down the side of the arm and
onto the bush sleeve? These type of grips have a very high leverage, and will self lock as you turn against them, mole grips tend to be too soft in
the flutes and usually round off when put under high load.
As the bolt is only siezed in the sleeve it doesn't matter if you're turning it in or out, whichever damages the mounting the least is the
best option, once it's moved a bit it will free off quite quickly.
If not, i would use a sabre saw/slitting discs to cut up the arm until just the bush sleeve remains, then cut slits on opposite sides of the sleeve
and split it with a chisel - you will not be able to cut through the sleeve right up to the edge, unless you have something like a oscillating
multitool that cuts square to an edge, this may be the only option if the sleeve is recessed deeply inside the mounting location.
Dave
Personally I'd be taking the whole strut off the car and work on it on the bench. Sounds very rusty, time to do some dismantling with a grinder and get some new bolts. It's usually about this time you find quite a few things needing replacing. Watch what you heat as you may alter the metal properties which can be dangerous on suspension and steering components.
Personally I'd be taking the whole strut off the car and work on it on the bench..
Originally posted by obfripper
Is there enough room to get some parrot grips like this down the side of the arm and onto the bush sleeve? These type of grips have a very high leverage, and will self lock as you turn against them, mole grips tend to be too soft in the flutes and usually round off when put under high load.
As the bolt is only seized in the sleeve it doesn't matter if you're turning it in or out, whichever damages the mounting the least is the best option, once it's moved a bit it will free off quite quickly.
If not, i would use a sabre saw/slitting discs to cut up the arm until just the bush sleeve remains, then cut slits on opposite sides of the sleeve and split it with a chisel - you will not be able to cut through the sleeve right up to the edge, unless you have something like a oscillating multitool that cuts square to an edge, this may be the only option if the sleeve is recessed deeply inside the mounting location.
Dave
Can you jam something in to stop the bush sleeve from spinning?
Maybe knock centre punch in if space allows.
These are good for removing annoying parts, like turrets etc.
I finally got it apart. Previous efforts to unscrew had already started to push the stuck sleeve through the side of the housing. I decided to go
along with this, as the damage had already started and I figured that I could bend the raised metal back and weld a piece over it to restore the
integrity. That only partly worked, as the bolt ran out of thread when the sleeve was only 1/4" out, but it was still held tightly in the rubber.
After various attempts to lever while turning, I burnt the rubber out. extracted the bolt and sleeve and fixed up the damage.
I have since had the bolt and sleeve in the garage, tightened into a bench vice using a hammer to get it ultra-tight and used an air-impact gun. The
bolt is still stuck firmly in the sleeve. I am giving up on that and will find somewhere to buy a new bolt.
Big hammer and the bolt lying on an anvil (or the vice). Hit the slieve, working around it repeatedly useing lots of easing oil. Eventually the shock will break up the rust and the tube will come loose. Heat will also help.
