The other day a mate of mine asked me to look at his wife’s car as it would not start .
I had a look and asked him to try and start it no go But turning over ok so got him to open the bonnet I could see nothing wrong.
Then I said are you pressing the clutch pedal the answer I got was no Press it hay pressto. It started
The funny part is they have had the car for about 8 years and I know my mate drives it about
[Edited on 11/2/24 by jacko]
My missus once called me out about a 'flat battery' on the jeep, because she'd forgotten, after 5 years, that you had to press the clutch for it to turn over!
They've probably been pressing it without thought for years and then forgotten, just the once and not pressed for the subsequent re-tries as the sequence has been disrupted. I was certainly taught to hold down the clutch, check the gearbox is in neutral and then start the engine, before letting the clutch up slowly - in days where the car would actually start without any of that.
you have to press the brake on many auto trans cars
On my astra clutch to start and brake before turning the electric hand brake off
It is a pity that the clutch to allow starting feature of modern manual cars cannot be overridden. Some years ago, the underbody jets of a car wash
soaked the ignition of my car and it would not start. I was able to use the starter to drive it out of the car wash, allowing it to dry out out of the
way.
Many years before that, my father's car cut out when driving through a ford. We left it for some time to dry out, before having a sudden
revelation and realising that it was not wet electrics at all, but the impact switch having cut off the fuel pump, as the tow-bar bottomed when
entering the ford. Once reset, we were on our way. Again, we had managed to move the car, on the starter, to clear space for traffic to pass us while
we were stuck and mistakenly letting it dry out.
Best part of 50 years ago when I was an apprentice I was sent out on a breakdown , my manager had collected a customers mk10 Jaguar and managed to stall it at a junction. When I arrived I jumped in and started it. When asked how I started it I said pressed the starter button, I was sworn to secrecy by a red faced manager!
My sister in law travels asked me to look at her cigarette lighter as the USB charger was not working on her phone. After basic checks all looked good, I plugged in my cigarette lighter usb and all was good. Turns out my brother had swapped cigarette lighter adapters and her new one was really short. It could not reach to the bottom of the socket for the positive feed.
