zetec
| posted on 13/2/10 at 04:56 PM |
Ford focus ignition fault.
My Focus 1.6 petrol has gone into limp home mode. Checked easy things like plugs, connectors etc and all OK. Next checked if sparks at plugs using a
strobe, and 1+4 no spark from coil...great I thought, tried another spare coil but same thing??? Wondered if ECU needed reset to get out of limp home
mode. Called local mobile mech with ECU software. He checked and said the coil was showing faulty, without a second thought he changed it, dispite me
saying I had already tried another...still same fault so out come new coil and old one back in. Getting an error code p0351 which is saying the coil
circuit is faulty. Also tried swapping plug leads just in case. Anyone any ideas? Poss ECU to coil cable fault or ECU driver circuit fault as looks
like feed for that side of wasted spark coil pack faulty...
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
beaver34
| posted on 13/2/10 at 05:15 PM |
sounds like faulty coil again, commen for coils to drop though, ive got afew spare in the garage incase mine goes
DRC INDY 7
| posted on 13/2/10 at 05:16 PM |
choice of 3 items relating to p code p0351 ignition coil a primary/secondary-circuit malfunction
1 Wiring
2 Ignition coil
3 ECM
Puddle Dodgers Club
davie h
| posted on 13/2/10 at 07:40 PM |
i had a focus do the same tried a new coil and it still missfired, after a closer look one of the wires on the plug at the coil was snapped inside the
plastic insulation very close to where it entred the plug. only noticed it because the wire was slightly bent. worth checking.
davie
[Edited on 14/2/10 by davie h]
http://www.flickr.com/photos/24179682@N04/?saved=1
norfolkluego
| posted on 13/2/10 at 11:34 PM |
My Mrs used to have an 02 reg Fiesta, that was always going into 'limp home', turn it off, wait 5 mins and it was OK, Ford dealers always
said, there was nothing wrong with it, yeah right.
(Probably doesn't help)
