MK9R
| posted on 18/3/10 at 10:11 AM |
Fiat ducato parts supplier
Looking for a speedo cable for a fiat ducato van and struggling to find a good parts supplier online, any recomendations
delboy
| posted on 18/3/10 at 06:09 PM |
Are you sure you need a speedo cable? they are really prone to the plastic drive on the box failing, the speedo then dosen't work and its often
assumed that it's a failed cable. Just though it might be best to let you know, just in case.
MK9R
| posted on 22/3/10 at 10:03 AM |
I pulled the cable inner out from the guage end, the cable was broken, so i assume its the cable!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
| posted on 22/3/10 at 10:04 AM |
i've not removed the bit that goes into the box, can you tell if its failed by removing that?
Cheers Austen
RGB car number 9
www.trackace.co.uk
