Author: Subject: Help with info please
jacko
posted on 24/2/12 at 05:53 PM Reply With Quote
Hi all my good friends
I have a Vauxhall Vectra C and the airbag light is on , I know what is making it come on its the cartridge / tape in the steering wheel .
What i want to know is what type of job is it to replace this part
The part is priced at £204 +vat and if its replaced at a main dealers i will get very little change out of £400
This will have to be sorted for its MOT next month
Jacko
Daddylonglegs
posted on 24/2/12 at 06:01 PM Reply With Quote
Take out the bulb for the MOT?
Ninehigh
posted on 24/2/12 at 06:05 PM Reply With Quote
Personally I wouldn't go near the airbag area... Might well be easier to remove the bulb!
loggyboy
can't do that anymore, they check it comes on at start up and ensures it goes out..
SALAD
posted on 24/2/12 at 06:06 PM Reply With Quote
Would it be cheaper to buy a replacement steering wheel from a popular auction site, perhaps the one that rhymes with tea tray?
I took my BMW wheel off and noticed the tape. It was easy to access but I don't remember how it attached.......that was WELL helpful wasn't it.
[Edited on 24/2/12 by SALAD]
jacko
posted on 24/2/12 at 06:09 PM Reply With Quote
NO
SALAD
posted on 24/2/12 at 06:18 PM Reply With Quote
Yeah sorry, but have a look on tea tray.
PSpirine
posted on 24/2/12 at 06:24 PM Reply With Quote
The cartridge (containing clockspring lead) can be replaced very easily on most cars. Just look out for a complete steering wheel on ebay, complete with airbag and clockspring/connector.
deltron63
posted on 24/2/12 at 07:24 PM Reply With Quote
It's easy to change the clock spring, just make sure you dont play with the new one by turning the center around.
If you diy disconnect the battery for 20 minutes before you remove the airbag.
britishtrident
posted on 24/2/12 at 07:25 PM Reply With Quote
On most cars the spring has to be taped before removal or the clock spring will unwind how many breakers would know this.
[Edited on 24/2/12 by britishtrident]
[/I]
bi22le
posted on 24/2/12 at 07:54 PM Reply With Quote
I have done this many times on a variety of cars and would give it a go myself. I may have to do one on my brothers clio soon and have not done any for over 5 years, still confident I can do it.
Before starting check you have the radio code!
1) Disconnect battery (dont unplug anything for a good 30mins)
2) Centre the steering wheel.
3) Take the cover off of the centre of the steering wheel and take out the old air bag, anything that is to do with the airbag and accident system has to be yellow, anything that’s not will be horn and steering controls for the radio. Removing the air bag (you may not have to do this but IIRC most of the time you do) will give you access to the main bolt holding the wheel to the column.
4) Undo the bolt but DONT take it off.
5) Pull on the steering wheel with all your might. It wont come off and smack you because the nut is still on, you know what position its in because you centred it, its a pain to come off because its not meant to!
6) Underneath the wheel be a yellow circular disc cassette thing. Its called a clock spring but it wont go crazy and unravel like a nightmare, its contained and easy to handle. It will have instructions on it and screws holding it in place. Undo and remove.
7) replace with new one. Again IIRC there are arrows on the yellow cassette that state the central position of it so that it achieves lock to lock without snapping.
8) Reverse processes.
Have a cup of tea and biscuit as you marvel at how easy the job was.
If the light is still on then it may not of been \ or was not the only fault with the system. Check the plugs under the seats. Also check the old cassette with a multi meter to check continuity. This will tell you if anything was even wrong with it! There should be NO resistance, I think!! The ECU should not need reprogramming as the airbag system is live checking therefore does not latch log faults and throw fault codes via the instrument panel.
Finally do a youtube search or google search somebody may have specific Vectra C data. This advice is from experience but also from 5 year old memories.
Good luck, be bold and disconnect the air bag at arms length!
Biz
Please read my ring story:
britishtrident
posted on 24/2/12 at 08:03 PM Reply With Quote
Above is spot on............
[/I]
hillbillyracer
posted on 24/2/12 at 08:24 PM Reply With Quote
Working out how to remove the centre of the steering wheel & then doing it is likely to be the hardest part of the job, the rest is just taking care & working logically as the above advice says.
Got the one to do on my van soon, I let the wheel turn too far when I had the column off to put a rack in it.
bi22le
posted on 24/2/12 at 08:47 PM Reply With Quote
normally the centre cover will just pull off as screws in soft bits that the head could hit is frowned upon!!
Be bold and give it a tug. its normally attached by a bit of webbing to stop it flying off during air bag deployment.
hillbillyracer
posted on 24/2/12 at 10:05 PM Reply With Quote
I know the one on my VW van needs a tool (a thin screwdriver will do but VW probably have a one for it) to bend a spring back at either side of the wheel, accessed through holes on the back side of the wheel. Once you know what to do it's mearly awkard, before that somewhat more difficult. It does just shove back on though!
