| posted on 12/6/12 at 01:33 PM |
Tin top full service
Just completed a full service on my Passat TDI and what a difference it's made. 57 plate car with 76k miles, purchased from first owner at 62k
miles with full VW service history. Car was starting to feel unresponsive and slightly hesitant at higher (3k+ revs).
Cam belt, water pump, tensioners and aux belt
Fresh coolant
Air filter
Oil and filter
Pollen filter
Fuel filter
Brake fluid
4 new Dunlops (the budget Kenda tyres really were sh1te)
The car is transformed, feels much smoother and faster and pulls cleanly to the read line. It's also stopped the annoying belch of smoke on
start up too.
Now ready for Le Mans this weekend
Agriv8
| posted on 12/6/12 at 02:42 PM |
Good Job,
But double check you have replaced the oil filler cap ( and clipped it home ! ) as speaking as someone who has not it makes a right mess.
PS What oil have you gone for did you get the timming bely set as a kit as my A6 is due at next service?
| posted on 12/6/12 at 06:14 PM |
All checked and correct.
It's on a long life service (VW 507 spec oil) so supposedly every 18-22k miles. I used Halfords own brand which meets the VW spec, but will
probably change every 12k any way.
Cambelt kit was sourced by the garage that did it (local VAG independent).
All other parts were genuine VAG from www.zakparts.co.uk (highly recommended).
