CraigJ
| posted on 20/1/10 at 08:22 PM |
VAG COM features?
Does anyone here use VAG-COM? does it have the ability to recode a new ECU to a car?
Thanks Craig.
jeffw
| posted on 20/1/10 at 08:31 PM |
Suggest you ask your question here
http://www.ross-tech.com/
These are the people who make the VAG-Com & VCDS.
tegwin
| posted on 20/1/10 at 08:33 PM |
I use it on a pre Can-Bus Polo GTI...
Any yes, the full version can recode all modules Mighty useful!
www.verticalhorizonsmedia.tv
thefreak
| posted on 20/1/10 at 08:42 PM |
I've used it on the missus' old mk4 Golf TDI and my 02 A4. Recoded it after retro fitting the cruise control and the newer SCM.
There's a wiki on what all the modules mean and what values are needed.
All you need then is the USB cable. Think I paid a tenner for mine.
CraigJ
| posted on 20/1/10 at 09:15 PM |
Cheers guys.
clanger
| posted on 20/1/10 at 09:26 PM |
Used it with freeware version to diagnose a dashboard light on my Mk4 Gt Tdi. The freeware version just enabled you to find out the fault, but is
limited on resetting them.
Luckily mine reset itself when I changed the bit acting up.
Russell
| posted on 20/1/10 at 09:27 PM |
Yes you can and it's dead easy. You're actually coding the ECU to the immobiliser built into the instrument cluster.
Russ
I'm a bilingual illiterate. I can't read in two languages.
