Author: Subject: Converting 12v to 5v
speedyxjs
posted on 30/9/10 at 03:38 PM Reply With Quote
How do i go about it? Im in the middle of wiring an in car camera (T-eye) into a van but need a 5v 1amp supply.
TIA
carpmart
posted on 30/9/10 at 03:41 PM Reply With Quote
http://www.4kam.com/onboard_camera_bike_cam_power.htm
4th item on the page in the link!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
lewis
posted on 30/9/10 at 03:43 PM Reply With Quote
I have a ciggy lighter converter for my camera,you could butcher one of those to wire in to get your 5v mine has a max of 1.5A so should be fine for your app.
tegwin
posted on 30/9/10 at 03:59 PM Reply With Quote
Go to Maplin/rswww/rapidonline and buy a 5v voltage regulator... its a three leg device.... one leg goes to 12V, the otherto gnd... and the last one, you guessed it, is 5v!
Should be around 50p...
edit for a link
LINK!
[Edited on 30/9/10 by tegwin]
www.verticalhorizonsmedia.tv
jossey
posted on 30/9/10 at 04:10 PM Reply With Quote
usb charger. some change the volt to 5v from 12v.
hope that helps.
dave j
rf900rush
posted on 30/9/10 at 04:11 PM Reply With Quote
Model arcraft's use thing called BEC's
Battery Eliminator Ciruits
Like THIS ONE
Martin
coyoteboy
posted on 30/9/10 at 04:18 PM Reply With Quote
tegwin's component is not the only component required for the task if you want it done properly - you need some filter caps and some decent protection for your expensive camera. The automotive electrical environment is very unpleasant! While I'd build one myself, it's cheaper and easier for most people to buy a ready made package that will do the job without risk or faff. That said, it's nothing more than a couple of quids worth of components in a box, so don't pay ££££ for it.
Rod Ends
posted on 30/9/10 at 04:31 PM Reply With Quote
www.maplin.co.uk/Module.aspx?ModuleNo=400260
MikeR
posted on 30/9/10 at 06:28 PM Reply With Quote
i've built a maplin module that does it - nice evenings entertainment.
