mcerd1
| posted on 16/8/11 at 09:45 AM |
OT - Tin-top steering problem (again!) - update
right folloing my last thread (linky) I've tripple
check it now and I'm more than 100% sure its not the column
(that would have been easy to sort)
I actuall disconnected the column but the 'sticky spot' is still there
the only thing that seems to affect it is taking the weight off the wheels, also its worse turning left than right - so I disconnected the track rod
ends but I can't fell anything wrong with the struts either...
so I'm suspecting the rack
any more thoughts ?
[Edited on 16/8/2011 by mcerd1]
| posted on 16/8/11 at 10:39 AM |
Bent rack,, but first try slacken the rack mounting bolts off
mcerd1
| posted on 16/8/11 at 10:48 AM |
are you thinking that its clamped too tight ?
this rack is mounted to the sub frame with just 2 bolts through lugs cast onto the side....
btw - i just found this on youtube, its almost exactly the same problem as mine:
linky
