Author: Subject: Vinyl Wrapping
omega0684
posted on 15/7/12 at 01:51 PM Reply With Quote
Vinyl Wrapping
hi All,
Do any of you have any experience with Vinyl Wrapping? i want to wrap my ali side panels but i have never done it before, i do have a spare panel i can practice on. What's the best way to prevent air bubbles etc?
Any advice is greatly appreciated
All the best
Alex
posted on 15/7/12 at 01:58 PM Reply With Quote
Patience and talent required, I wrapped my scuttle n wind deflector.. would cringe at the thought of a whole side panel, although its flat so maybe....
sdh2903
posted on 15/7/12 at 02:02 PM Reply With Quote
Side panels are a doddle. Its when you get to curvy bits it gets interesting!
Use a spray bottle with some warm water with a drop of fairy liquid in it and spray onto the panel. Start at one end and using an applicator push along working all the bubbles and fluid out. Use a hairdryer to keep the vinyl pliable.
One thing i would say is, the better the vinyl the better/easier it will be. Some of the cheap ebay stuff is a pig to use and looks poo.
madteg
posted on 15/7/12 at 02:19 PM Reply With Quote
Watch a couple of videos on youtube before you start, but side panels will be easy as long as you bye the 3m stuff. Good luck.
Pat_T
posted on 15/7/12 at 02:35 PM Reply With Quote
I did my whole car bar nosecone. It's not easy but nor is it particularly difficult once you get used to the material. Get the professional stuff from Hexis or 3M.
Cost me the sum total of £68
Check out the link in my sig for pics!
www.instagram.com/patroclueus
bi22le
posted on 15/7/12 at 05:10 PM Reply With Quote
Do you have rivers on your side panels?
I made up a super sharp punch to cut holes around the rice heads once the vynal was applied. It finished off my side panels a treat.
I have some pics in my folder.
All above advice is sound. Strip the car sides down to aid access, get a friend or two as well. The vynal is a pig to handle in large sheets to be applied vertically.
Please read my ring story:
RK
posted on 15/7/12 at 10:40 PM Reply With Quote
Side panels don't need good stuff. The curvy bits do. Extremely rewarding work.
Steve Hignett
posted on 16/7/12 at 05:16 AM Reply With Quote
It'll be a piece of wee-wee matey.
If you are at all phased by it, then I'd be more than happy to travel down to you and put it on for/with you...
Obviously, I'll be doing this for free, and I'll pay for the fuel to get to you, and if it's the 3M CF you fancy doin it in, then I'll buy it for you too.
It's the least I can (should) do really...
