Author: Subject: Pantograph pull out door mechanism info needed
balidey
posted on 22/12/09 at 12:14 PM Reply With Quote
Kind of car related, its for a truck.
I need to design a vehicle door that pulls out and swings to one side. I believe these are called pantograph hinges. The kind of thing found on race transporter belly lockers for opening doors parallel to the body.
I have googled for info on them, but all I get is a couple of crappy pictures and no real detail of the hinge mechanism
So has anyone got some good photos of the mechanism, or engineering drawings?
I am going to model the mechanism on Solidworks, but I need a good starting point. Can you locostbuilders help?
Thanks in advance.
Mr Whippy
posted on 22/12/09 at 12:23 PM Reply With Quote
why not use the hinge from an old coach bus door? like this -
balidey
posted on 22/12/09 at 12:25 PM Reply With Quote
Thats the sort of thing I want, but I need details of the actual mechanism.
Or this...
but again, I need details of the mechanism only
[Edited on 22/12/09 by balidey]
Mr Whippy
posted on 22/12/09 at 12:31 PM Reply With Quote
balidey
posted on 22/12/09 at 12:41 PM Reply With Quote
Genting very close Mr Whippy, thanks. just need to rotate and enhance like on CSI
tegwin
posted on 22/12/09 at 01:00 PM Reply With Quote
Amagingly if you do a google images search for "pantograph door hinge"... it magically brings up quite a bit of information... some of it looks like it might be relevant!
www.verticalhorizonsmedia.tv
Confused but excited.
posted on 22/12/09 at 01:03 PM Reply With Quote
Isn't what you are looking for a parallelogram, as opposed to a pantograph?
Pantograph is just a scissor mechanism as on the pick-up on leccy choo choos.
Or something like this any good?:
https://www.sugatsune.co.uk/index.php?module=catalogue&action=category_view&category_id=00130019
[Edited on 22/12/09 by Confused but excited.]
balidey
posted on 22/12/09 at 01:25 PM Reply With Quote
Done that already. And I've looked at the cupboard door page too
I need to engineer one of these, so need details of the shape of mechanism. All the links and google are surprisingly short of good information.
Parallel motion or pantograph both similar, if not the same??? so I'm not bothered what its called, I just need info on the mechanism on a door that pulls out and moves in a parallel action to the side.
posted on 22/12/09 at 01:34 PM Reply With Quote
Well that looks like a shadey old set of wheels plenty of overspray and what looks like a bit of 40mm box welded in. Is it one of you're fleet Whippy
balidey
posted on 22/12/09 at 05:57 PM Reply With Quote
sorted now, i just made up my own model and it seems to work fine.
blakep82
posted on 22/12/09 at 06:07 PM Reply With Quote
if i remember right the bus doors are just like a J shape arm? i forget how it keeps the door parallel to the side of the bus though
________________________
