Alan B
| posted on 28/12/09 at 12:54 PM |
Tin top Q - Focus A/C (aircon) compressor
As above, mine is very noisy and was smoky..seems like it has seized up/burnt out.
I can get a compressor fairly cheaply to replace it.
Is there anything particular I should be aware of or any tips for doing this job?
Cheers in advance,
Alan
mookaloid
| posted on 28/12/09 at 01:13 PM |
well you will need to get an aircon specialist to degas the system then regas after you have changed the compressor
Alan B
| posted on 28/12/09 at 01:39 PM |
Cheers Mook...
What if don't want to do that part just yet (the garage bit) ? Is it ok just fit the new compressor and allow the pulley to idle, or is it more
complex than that?
Alan
mookaloid
| posted on 28/12/09 at 01:46 PM |
Sorry I'm not familiar with that particular car but I know that degassing and regassing is not a DIY job and it would be irresponsible (and
possibly illegal) to let the refrigerant out into the atmosphere.
The ones I have had dealings with, you couldn't do as you suggest as you have to break into the gas circuit to change the compressor.
| posted on 28/12/09 at 01:57 PM |
The degassing and regassing isn't complex it is just tied up in environmental regulations because the refrigerant gas is ozone depleting gas
and also a minor green house gas it has to be recycled.
Modern cars use R134a refrigerant gas which breaks down due to action of sunlight in the upper atmosphere and causes much less damage to the ozone
later than thje old style refrigerants.
If the gas had already leaked out you could change the compressor yourself and take it to Halfords or a propper AC specialist to get vacuum pumped
and refilled.
Or if you can bodge a vacuum pump fill it using DIY refill cans and a pressure gauge.
http://www.carairconditioningsupplies.com/caraircon/home.php?cat=30
[Edited on 28/12/09 by britishtrident]
Alan B
| posted on 28/12/09 at 03:06 PM |
Thanks guys...great info. and help.
jonesier1
| posted on 28/12/09 at 04:24 PM |
its prob only the clutch or the clutch bearing thats gone and can be done without degasing or removing the compressor,just take off the aux belt undo
the eight/ten mill bolt and the clutch will start to come apart then there maybe a very small c clip and the rest will prise off.not very often the
compressor fails .
im in my own little world...its ok though they know me there
Alan B
| posted on 28/12/09 at 04:35 PM |
Cheers Jonesier,
That's definitely worth a look....I'm all for saving a bob or two (or buck or two in my case)
Fortunately, I can strip if first and see what it needs without the pressure of it having to be back on the road at a specific time. (IOW, I'm
using a different car right now..)
