omega0684
| posted on 1/2/10 at 09:32 AM |
radiator question
radtec are offering to powder coat radiators for £35, but why would you powder coat a radiator surely it would make the rad less efficient?
sucksqueezebangblow
| posted on 1/2/10 at 09:50 AM |
Black surfaces radiate (and absorb) heat faster than lighter surfaces. Equally, powder coat probably has insulating properties that might reduce heat
transfer, so it is really a question of whether one effect (radiation) is greater than the other (insulation).
Mark Allanson
| posted on 1/2/10 at 09:53 AM |
If the YTS kid had mistakenly painted a load or rads, what would you do with them?
speedyxjs
| posted on 1/2/10 at 10:10 AM |
I just sprayed mine with hammerite
Il be getting a new one post IVA anyway.
r1_pete
| posted on 1/2/10 at 10:25 AM |
I'd guess its just the tanks, not the matrix, powder coating that would surely make the rad useless.
Bluemoon
| posted on 1/2/10 at 01:20 PM |
dito, unless the coating thickness is small, I doubt powder coating process works that well anyhow for the matrix as you need a local electric feild
to get the powder to attract, and there will not be any between the fins as they are at the same potential (at least that's my
understanding)...
A thin coat of paint/powder coat would be fine.
Dan
[Edited on 1/2/10 by Bluemoon]
ReMan
| posted on 1/2/10 at 10:28 PM |
Presumably to make them look more original on older moters?
