omega0684
| posted on 8/2/10 at 08:40 AM |
fuel pot?
Any good for the money?
Ebay Linky
designer
| posted on 8/2/10 at 08:51 AM |
Why has it got so many connections?
snapper
Fuel pots like this are about £55 without the fittings, fittings are from £10 each for the straight ones £25 for the 90 deg £95 new ish
deezee
| posted on 8/2/10 at 09:10 AM |
I wanted to ask the same thing, but don't wanna sound daft! I'd have thought you only need an fuel in, fuel out and a fuel return from
the feed rail.
speedyxjs
| posted on 8/2/10 at 09:37 AM |
the feed rail.
thats what i was thinking but you may also need a non return valve?
MikeR
| posted on 8/2/10 at 09:43 AM |
at a completely random guess, twin pumps feeding the swirl tank and its feeding two banks of injectors, each with their own pump.
l0rd
| posted on 8/2/10 at 10:57 AM |
+1
Although this particular one doesn't look well thought.
I believe, that the fittings for the fuel return from the rail and the low presure fuel pump are supposed to be welded on an angle and not vertical on
the swirl pot.
[Edited on 8/2/10 by l0rd]
lsdweb
| posted on 8/2/10 at 01:24 PM |
the swirl pot.
Why? The one you've shown (made by Spencer) looks fine and his work is usually very good!
flak monkey
| posted on 8/2/10 at 01:39 PM |
A proper swirl pot has 4 connections like the pic above.
Bottom is the outlet to HP pump.
2 on the side are main fuel in from LP pump and return from FP regulator.
Top on is return to the fuel tank.
Sera
http://www.motosera.com
l0rd
| posted on 8/2/10 at 01:48 PM |
the swirl pot.
Yes, this is the correct way a fuel swirl pot should be. The one on ebay that omega0684 is looking at doesn't have the fittings like that.
I was reading about fuel swirl pots, can't remember where, but it was saying that the fittings should be on an angle as it is better for fuel
circulation.
lsdweb
| posted on 8/2/10 at 08:41 PM |
Swirl pot?
These are just small fuel tanks, built to ensure a permanent supply of fuel to the HP pump and rail, to avoid fuel surge on cornering etc..
Why would you want to swirl the fuel?
l0rd
| posted on 8/2/10 at 09:25 PM |
Swirl pot?
i think for better flow.
