hairydan
| posted on 19/2/10 at 07:09 PM |
lost keys
evening all,I have lost my keys for my 97 escort van.Is there anyway of bypassing the immobiliser?
HD
big_wasa
| posted on 19/2/10 at 07:37 PM |
No
Take the ecu out it will have a name. just buy another with the chip.
For a ford dealer to plug it in and re code the ecu to new keys will cost loads.
hairydan
| posted on 19/2/10 at 07:46 PM |
ok will do.
cheers
HD
jonesier1
| posted on 19/2/10 at 09:26 PM |
easiest way is to remove a door lock if its open and strip it,the tumblers will have notches or numbers on relating to key cuts (1 being no cut and 4
being cut deepest)then get a key cut and programmed.if its a petrol van then just program to ecu if its diesel then ecu and r.i.m module (on the
pump).No good just buying an ecu if its diesel as mentioned the pump has a remote immobilizer module (rim)that needs to be programmed as well.
im in my own little world...its ok though they know me there
sparrks
| posted on 19/2/10 at 10:02 PM |
If its a diesal remove the rim module behind this is the fuel stop soloniod if its got a single wire put 12 ignition live to it if it has more than
one wire buy a single wire soloniod and fit that then all you have to do is put a newwire from ignition swich(starter side) down to the starter
motor
jub done
hairydan
| posted on 19/2/10 at 10:23 PM |
thanks for the replies,should of said its petrol.might go to the scrapie and get the ecu and key and the bits.
HD
big_wasa
| posted on 19/2/10 at 11:18 PM |
hmm my reply did asume petrol as I now nothing about diesel's.
I do know a bit about the Pats on the petrol eec-v and you wont bypass it.
early models you would need the red master key to pair another. Latter models would need two keys to pair a new one.
[Edited on 19/2/10 by big_wasa]
Ninehigh
| posted on 20/2/10 at 12:20 PM |
Temporarily lost the key for the mondeo, so I took the spare (proper spare from dealer too) and all it did was unlock the doors! I felt like a right
pillock sat on my drive with the alarm going off and engine running
