maskell01
| posted on 20/2/10 at 09:43 PM |
My crap fiat punto
well!where do i start!
the clutch was on its way out!so i bit the bullet and replaced the bugger!
clutch is fine but whenever i drop it down a gear at slightly higher rev's,causing it to engine brake,there is a big clunk!almost as he its
forcing the gear in to location!
any ideas?
Daddylonglegs
| posted on 20/2/10 at 09:47 PM |
Anything on the market that uses it as a donor?
Duncan Mould
| posted on 20/2/10 at 09:48 PM |
Fix it again tomorrow (fiat)
sounds like the gearbox, they often give that sort of noise out when decellerating. Alternativly have you checked all of your mounts?
snakebelly
| posted on 20/2/10 at 10:00 PM |
just delivered the wifes punto hgt to the breakers yesterday bloody thing has cost me a fortune over the last year and i certainly wasnt going to
replace the engine after a big end has gone, the local fiat dealer used to rub his hands when i turned up....never again!
ashg
| posted on 20/2/10 at 10:02 PM |
if its a 1.2 its quite common for the difs to explode and exit through the casing. the old bravo 1.2 box is stronger and will fit the older punto
engines
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
maskell01
| posted on 20/2/10 at 11:10 PM |
its coming close to changing from my crap fiat punto to my cubed fiat punto!
Mark Allanson
| posted on 21/2/10 at 12:16 AM |
If its a 1.2 8v, then the head gaskets don't last more than 30k, some of the heads a porous and cannot be skimmed - such joy!
| posted on 21/2/10 at 08:52 AM |
Case hardened spaghetti!
| posted on 21/2/10 at 12:01 PM |
Sounds like a needle roller bearing in the gearbox main shaft is seized --- causing friction between the two ends of the shaft in effect it is like
trying to engage to gears at once. --- usual cause is low oil level, only cure is strip the box or new gearbox.
