Author: Subject: Ford key issue
mookaloid
posted on 15/7/10 at 12:59 PM Reply With Quote
Ford key issue
I have very generously bought a ford Ka for my daughter to learn to drive in - however it only came with one key for the ignition
Ford want £95 to program a new key if get one cut
I can't believe I have been caught out with this one as I used to work in the trade and I'm supposed to know about this stuff
So has anyone got any bright ideas on how or whether I can avoid this £95 for 2 minutes work charge from the ford main stealer?
Mooky
Dingz
posted on 15/7/10 at 01:08 PM Reply With Quote
Our local Timpsons, shoe repairs and key cutting can cut some coded keys, for about half that. Haven't tried them yet as didn't have the key with me. If there is one near you may be worth asking.
went on and on.
posted on 15/7/10 at 01:18 PM Reply With Quote
that's cheap. Nissan want £ 300!!
you can get key cut at key cutting shops but it is the programming (for alarm/immobilisingingatator) that is the expensive part.
balidey
posted on 15/7/10 at 01:25 PM Reply With Quote
Dealers will tell you its only them that can program keys, but as said, most Timpsons and others can infact do it for a fraction of the cost. Go into your local key cutters and ask.
Dutch bears have terrible skin due to their clogged paws
Danozeman
posted on 15/7/10 at 01:43 PM Reply With Quote
As said alot of key cutting places with cut it and clone the code from the original key.
Dan
Madinventions
posted on 15/7/10 at 01:52 PM Reply With Quote
Wow - that's good to know! I've only got one key for my Mojo (Ford ECU etc) and always wanted to get a spare but didn't like Ford's prices.
Now to find somewhere local that does this service... Any ideas Dan?
Ed.
View my band website:
http://www.shadowlight.org.uk
UncleFista
posted on 15/7/10 at 02:21 PM Reply With Quote
The following worked for my stepdad's 8-9 yr old Mondeo a week or 2 back.
Dealer says it's a dealer only procedure, Autodata says otherwise.
This was for a 2nd hand replacement "3 button" remote with a new key "blade", see pic.
Does your key look anything similar ?
for mondeo key
for mondeo key
from autodata:
to reprogram remote:
turn ign to pos II 4 times in 3 secs.
switch off, remove key
clock led should be on, you have 20 secs
single battery key: press any button , led should flash
if you have more keys to program wait two secs and press the button on the
other key
to end turn ign on, wait 20 secs
then try the keys
[Edited on 15/7/10 by UncleFista]
Tony Bond / UncleFista
mookaloid
posted on 15/7/10 at 02:33 PM Reply With Quote
it's one of these by the way.
I think I might have found a local key cutter who says he can do it for £50-£60
beaver34
posted on 15/7/10 at 04:16 PM Reply With Quote
some ford you can programe them on there own, the ka you carnt
Snuggs
posted on 15/7/10 at 04:23 PM Reply With Quote
Get 2 spare keys cut then hide the original in the column shroud near the ignition switch.
The spare keys should now start the car.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
mookaloid
posted on 15/7/10 at 04:25 PM Reply With Quote
That's very cunning Clive not very secure though......
Danozeman
posted on 15/7/10 at 04:43 PM Reply With Quote
That wont work. You need the key in the barrel with the ring round the barrel for them to read properly. But it does work if you do that and tie the whole lot up under the dash and use a new ignition lock.
Ed i think Kings on felixstowe road in ipswich does it. CPW on waterworks street could well do it aswell, they are a proper locksmiths.
Dan
bmseven
posted on 15/7/10 at 05:50 PM Reply With Quote
Or Keys R us in Colchester
posted on 15/7/10 at 08:16 PM Reply With Quote
This is all worth knowing - I have a Ford Focus with 2 keys - but I need a spare for the bloke who runs the car wash where I park next to Manningtree station Mon - Fri.
I refuse to pay near-enough £100 for a key that will get used once a month when my car gets washed. I don't need the remote bit either - he can stick the key in the door, as long as it shuts the alarm off. I don't want to leave my 'proper' spare key with him either.
Looks like I'm off to CPW or Felixstowe road on Saturday!
ASH3
posted on 15/7/10 at 09:03 PM Reply With Quote
You dont need to tape the key next to the
ign barrel just the transponder out the key
that sits under the little plug in the key
handle and have as many keys cut as you like.
Worked at a Ford main dealer for 10 yr and
know this works well as for security who
knows wats gone on same can be done with
door locks so any key works theres another
story u2u me for details
Ninehigh
posted on 16/7/10 at 10:48 AM Reply With Quote
I got one of them as a "spare" for the mondeo, it opens the doors and starts the engine just doesn't switch the alarm off...
