| posted on 14/5/11 at 02:54 PM |
Horn badge
I've just finished fiddling with my steering wheel boss etc. with the aim of moving my wheel a bit closer and also to get a proper horn push in
the middle. Everything is working as it should, but now I'd like to put a nice badge in the middle of the horn push.
The only Sparco badge is a bit naff (and irrelevant, as the only Sparco bit is the horn button!) so I'm looking for an alternative.
Can anyone suggest somewhere that sells round stickers that may be suitable? I'm not looking for anything car-maker-related - just something
like chequered flags, Welsh flag, anything like that! Probably I need someone who makes stickers for trophies or similar.
The last resort is to make my own, but I'm finding it hard to raise enthusiasm, as it would probably involve metal spinning or similar (the
badge will mount on a slightly convex surface).
macc man
| posted on 14/5/11 at 03:15 PM |
I used a round key fob with lotus decal on it. Cut the tab of it and glued it on. You may be able to find a suitable decal to use.
big-vee-twin
| posted on 14/5/11 at 03:35 PM |
Try this site, they do custom ones and use your uploaded pic too design online and buy linky
http://www.triangleltd.com
Humbug
| posted on 14/5/11 at 04:42 PM |
Not sure of the size of the Sparco badge space, but my Mountney's badge is the same size as the ones for gear knobs (or key fobs, as above). I
googled and found e.g. these from Europa Spares.
