Author: Subject: mondeo duel mass flywheel
brookie
posted on 28/9/11 at 07:35 PM Reply With Quote
has above has any body replaced there duelmass flywheel with a solid one
it seem to make the cluch kit alot cheaper and my just gone
noc231073
posted on 28/9/11 at 07:43 PM Reply With Quote
yes its done all the time ...the same clutch is in the transit .. just make sure you order the right kit they are widely available.
if your clutch is gone more than likely the fly wheel is knacker also as its a common problem
fazerruss
posted on 28/9/11 at 07:47 PM Reply With Quote
Is it a TDCI ?
My brother tried it on a 08 corsa cdti it worked alright but made the engine sound like a tractor or should i say an older non common rail diesel engine.
I think the only reason they are on modern diesels now is to make them sound better.
"if assholes could fly this place would be an airport"
posted on 28/9/11 at 07:57 PM Reply With Quote
If you find debris on the starter drive the flywheel is about to become history.
Also the maximum allowable amount of free movement allowed in the flywheel is ISTR 25mm/1 inch with no excess looseness or clicks or crunching noises.
Personally if a 4 in 1 solid flywheel kit is available I would skip the checks and fit a 4 in 1 clutch kit.
jollygreengiant
posted on 28/9/11 at 10:06 PM Reply With Quote
IIRC, Valeo started manufacturing direct replacement solid flywheel kits some time ago.
jollygreengiant
posted on 28/9/11 at 10:10 PM Reply With Quote
They are there to allow for more torque to be put through the clutch by 'mr Averagecar driver' so that the torque is taken by the fly wheel (large diameter) in stead of the friction plate (small diameter). giving a smoother and quieter drive engagement and take up.
posted on 29/9/11 at 06:55 AM Reply With Quote
They really two purposes they act as a torsional vibration damper and as a drive line shock absorber to even out the torque fluctuations created by each firing stroke. By evening out the torque fluctions a DMF allows manufacturers to getaway with using a lower torque rated gearbox and drive shafts.
In modern diesels they can just about be justified but when used in petrol engines they are just an added complication.
adithorp
posted on 29/9/11 at 07:06 AM Reply With Quote
If going to a solid flywheel, bare in mind that there's been reports of Mondeos breaking the crank due to the lack of damping. Ensuring a damper front pulley is fitted is recommended to try and reduce this. Not actually seen one do it, but it's been reported in the 'trade press.
http://jpsc.org.uk/forum/
hughpinder
posted on 29/9/11 at 07:10 AM Reply With Quote
Don't quote me on this but I'm fairly sure I've heard of problems with crankshaft damage if you don't have the dual mass thingy to absorb some of the shock load from modern torqey engines. I don't know if its common or just possible though
Regards
Hugh
froggy
posted on 29/9/11 at 07:14 AM Reply With Quote
It amazes me how long people keep driving on a knacked DMf . I did a vectra last week that was so bad I had to cut the centre out to get at the flywheel bolts . Shop around as there are some good deals from the factors , euro car parts seem to be keenest on price at the moment .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
steve m
posted on 29/9/11 at 08:54 AM Reply With Quote
How do you know when DMF is going or even gone?
posted on 29/9/11 at 09:05 AM Reply With Quote
They usually start rattling, especially at idle.
steve m
posted on 29/9/11 at 09:09 AM Reply With Quote
My TDCI Mondeo has always been a noiser engine, compared to a friends Focus, wthe exactley the same TDCI
does that mean my woes will start soon .....................
907
posted on 29/9/11 at 09:30 AM Reply With Quote
My Passat 1.9 TDI had a distinct rattle when turning the ignition off from tick over.
Also, when pulling away from standstill in 1st gear it was difficult not to get clutch judder.
A new DMF transformed the car.
I think that they deteriorate so slowly that you tend not to notice.
Paul G
adithorp
posted on 29/9/11 at 10:24 AM Reply With Quote
To be certain you have to measure the play in it but... You'll hear anything from a slight rattle to a low rumble in neutral, that will often alter with pressing the clutch and you may get clutch judder setting off. I've seen quite a few rattle for years without further problem but the rumble is usually terminal. As said by BT on the Ford TDi you'll also get fillings in the starter often causing falure of it (lots of suppliers won't warrenty replacment starters on them because of this).
posted on 29/9/11 at 10:47 AM Reply With Quote
Other thing to check when doing the job is the condition of the big bush on the lower engine tie bar --- an expensive part but you can rebush them using a Peugeot diesel engine mount bush which costs about £10 and is slightly stiffer but you need to enlarge the hole to 12mm and pack the width with washers.
(How i know this is the Mondeo lower engine tie bar also fits the Rover 75s which is handy as the lower engine tie bars for diesel 75s are like gold dust.)
[Edited on 29/9/11 by britishtrident]
posted on 29/9/11 at 11:01 AM Reply With Quote
The service limit angular free movement on a DMF is surprisingly high I have seen some web pages quoting 50mm/2" as acceptable I have even heard tales of new flywheels with 50mm movement.
The new clutch will probably be a type with springs in the centre hub these last longer than the original LUK solid design which tended to suffer from fatigue failures and the springs help absorb any shock loads to the DMF.
The motor factor may offfer you a "National" brand at a keen price I have found these OK and prefer to LUK.
dave r
posted on 29/9/11 at 05:05 PM Reply With Quote
i have a dmf sitting in my garage..... available if you want it
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
brookie
posted on 29/9/11 at 06:56 PM Reply With Quote
Is it a TDCI ?
yes it is m8 it the 2.2 tdci st 6 speed
brookie
posted on 29/9/11 at 07:00 PM Reply With Quote
this is the part im looking at
eBay - The UK's Online Marketplace
snakebelly
posted on 29/9/11 at 07:49 PM Reply With Quote
Fitted a kit from that seller to my 03 tdci estate approx 25k ago no noticeable noise increase clutch feels fine and as an aside ford now do a sanctioned single mass replacement for some transits so I take that as the green light.
Hth
