Author: Subject: Apart from Hondas, what other cars spin the wrong way?
TimC
posted on 2/11/11 at 02:58 PM Reply With Quote
I'm looking for a very compact starter that spins the same way as the B-series Hondas, that is the opposite to Fords, VX etc.
Anybody got any really bright ideas?
Daf
posted on 2/11/11 at 03:04 PM Reply With Quote
Wire it up the wrong way?
owelly
posted on 2/11/11 at 03:06 PM Reply With Quote
Turn it so it faces the other way. ie mount it in the bellhousing.
http://www.ppcmag.co.uk
adithorp
posted on 2/11/11 at 04:35 PM Reply With Quote
Only the Hondas as far as I can remember turn anti-clockwise. Quite a few starters do. Thats 'cos they're mounted from the bell-housing side on some cars FWD cars.
http://jpsc.org.uk/forum/
HowardB
posted on 2/11/11 at 04:36 PM Reply With Quote
It's no good just making the motor spin in the wrong direction, as the bendix screw will no engage the gear, so as above ^ mount a standard one the other way around.
hth
[Edited on 2/11/11 by HowardB]
Howard
Liam
posted on 2/11/11 at 04:46 PM Reply With Quote
The way a starter motor spins depends on whether its engine side or gearbox side and virtually any manufacturer will have either variety accross their range, so you dont have to look only to honda to find something thats the other way to what you have. I'm fairly sure wiring one up the wrong way could be problematic - they use the chassis/case as earth and even if you succeded getting one to spin backwards i think youd have problems with the solenoid/pinion not engaging and/or disengaging corectly. Damn it takes ages to type on one of these phone thingies.
posted on 2/11/11 at 09:34 PM Reply With Quote
Some older Simca (1000, 1100, Chrysler Alpine and Horizin) engines turn in the wrong direction
hicost blade
posted on 2/11/11 at 09:36 PM Reply With Quote
Evo 1-3's turn the wrong way
TimC
posted on 2/11/11 at 09:44 PM Reply With Quote
Cheers all - it's for an electric reverse mounted at the sprocket adaptor end.
loggyboy
posted on 3/11/11 at 12:41 AM Reply With Quote
Triumph Acclaim, but that was basicaly a rebadged Honda.
40inches
posted on 3/11/11 at 08:29 AM Reply With Quote
VAG starters run the "wrong way" check my archive and do a search for electric reverse. Been covered many times.
http://www.locostbuilders.co.uk/forum/29/viewthread.php?tid=113340#pid950418
[Edited on 3-11-11 by 40inches]
