Author: Subject: 2008 Corsa Heater Problem
cerbera
posted on 25/11/11 at 04:50 PM Reply With Quote
The misses has a 2008 Corsa with climate control. Recently the blower has been working intermittently and now is making a racket when working (noise is like a lolly stick on the spokes of a spinning bike wheel )
If the fan is turned on to the high setting it blows very slowly. Sometimes it won't blow at all but if you give it a bash it will start working again, albeit still noisy.
Anyone have an idea what's up, or is just plain old knackered?
Cheers.
iank
posted on 25/11/11 at 04:53 PM Reply With Quote
Fan bearing has probably gone, so knackered.
Anonymous
posted on 25/11/11 at 05:39 PM Reply With Quote
Used to have a Montego that did exactly that ----- used to smack the fan casing and it would work fine for a few months.
Either the motor is foobarred or there is debris in the casing.
perksy
posted on 25/11/11 at 06:59 PM Reply With Quote
Had similar to this on a peugeot
Stripped it all out and it turned out the fan had a crack in it
Cured it with Araldite
cerbera
posted on 28/11/11 at 04:21 PM Reply With Quote
Thanks for the replies.
The problem was that it was full of leaves. Cleaned them out and gave the bearing a liberal squirt of WD40 and Fanny's your aunt.
