smart51
| posted on 23/12/11 at 07:16 PM |
how big is a rubber suspension cone from a mini?
I'm looking for a rubber block to use as a suspension damper in my (pedal) recumbent trike. The mini rubber cone looks OK if it is the right
size. The thing is, all the pictures I've found have no reference in them. It could be an inch wide or a foot wide. How big are they?
Mark Allanson
| posted on 23/12/11 at 07:24 PM |
About the size of a well proportioned woman!
Mark Allanson
| posted on 23/12/11 at 07:25 PM |
I'm told a 38 D cup
smart51
| posted on 23/12/11 at 07:26 PM |
Ah. So perhaps not what I'm looking for.
hillbillyracer
| posted on 23/12/11 at 07:30 PM |
From memory about 4-5" diameter. I'd think you'd need a fair leverage ratio for the weight you're looking at as a pair carry
the front of a Mini with a ratio of a about 3-1 & the rear at 5-1.
Mabye a bump stop would be more in line with the weight you're dealing with?
smart51
| posted on 23/12/11 at 07:47 PM |
quote: Originally posted by hillbillyracerMabye a bump stop would be more in line with the weight you're dealing with?
That's not a bad idea. I've got a spare one somewhere too!
Brian R
| posted on 23/12/11 at 08:22 PM |
Anything here any good?
http://www.avindustrialproducts.co.uk/products.htm
| posted on 23/12/11 at 08:59 PM |
This might also be worth a look. Very similar to the way small trailer
suspension units work.
[Edited on 23/12/11 by MikeRJ]
iank
| posted on 23/12/11 at 11:13 PM |
The theory is fine, indeed the inventor of the mini suspension uses exactly the same for his bikes.
Maybe you can get a 'repair' part from his company.
http://www.moultonbicycles.co.uk/
Anonymous
AntonUK
| posted on 23/12/11 at 11:20 PM |
This may be to vague tbf, but iirc on either theminiforum.com or minifinity.com there is some drawings for adjustable cones that fit these donuts,
that might help? maybe??
Neville Jones
| posted on 24/12/11 at 01:56 PM |
quote: Originally posted by Mark Allanson
I'm told a 38 D cup
That size is about right, Mr. Allanson, but the age of the cup contents is all important.
A new cone is akin to an over 50's 38D, an old cone more like a firm and nubile 20 yr old.
