craig1410
| posted on 13/1/12 at 11:26 PM |
Wheel vibration on overrun at high speed. Cause?
Just out in my wife's SEAT Altea and noticed a quite severe vibration at speed. At first I thought it was a buckled wheel as the vibration was
quite bad and seemed to be from the front. Then I noticed the vibration went away when I accelerated regardless of what speed I was at. The vibration
does come back though as soon as you life off the accelerator and is worse the faster you go. At 90MPH it is really very bad and affects your voice if
you speak. At lower speeds like 50MPH you can hardly feel it and at 30MPH it is gone completely.
My thoughts are now CV joint but which one? Outer or inner? Also, I guess it could be gearbox related but I really hope not...
Car is a November 2005 Altea 1.6 Essence with 65k miles on the clock. We've owned it from new and it has been serviced every year, initially by
the dealer then latterly by me. It is due a service just now but I doubt that is the reason for the vibration.
Any ideas?
Thanks,
Craig.
l0rd
| posted on 13/1/12 at 11:35 PM |
wheel needs balancing or new tyres?
craig1410
| posted on 13/1/12 at 11:40 PM |
Well that's what I thought until I realised that the vibration can be switched on and off at the same speed just by feathering the throttle to a
slight power off to slight power on condition. If it was a wheel balance problem surely the vibration would be purely dependent on speed.
Also, I didn't notice the problem on the 20 mile journey from Kilmarnock to Glasgow, I only noticed on the way home which might indicate it is
heat related too (it was a continuous journey by the way as I was picking up my daughter).
locoboy
| posted on 13/1/12 at 11:45 PM |
Is it possible it could be a mounting of some sort?
Power on may preload the mounting and power off on overrun may unload the mounting allowing engine/gearbox to wobble about?
Is it related to revs or speed? If its revs then it could be to do with the clutch or DMF???
Locoboy
craig1410
| posted on 13/1/12 at 11:49 PM |
It seems to be road speed related, certainly in terms of severity and I think in terms of vibration frequency. As I said, it was quite severe above
80MPH to the point where I feared imminent failure of some sort. The trouble was it was difficult to slow down without lifting off the throttle if you
know what I mean...
It could be a gearbox or engine mount as I have just read that this can cause this sort of thing. I'll check in the morning. I don't think
it is a DMF as I don't think this car has one. It is a 1.6 litre 8 valve VW petrol engine. I could be wrong but I'm pretty sure this
engine harks from before DMF's were 'created'... I hope so anyway...
locoboy
| posted on 13/1/12 at 11:59 PM |
Have you tried feathering the brake pedal when on over run?
This can often eliminate or include certain possible causes, for example if it stops when braking then it rules out the clutch / gearbox assembly and
points more towards wheel bearing / CV joint/ drive shaft/bulge on the tyre or such like.
Locoboy
craig1410
| posted on 14/1/12 at 12:09 AM |
I know what you mean but I don't think braking had any effect other than to slow me down below the speed at which the vibration was as severe.
I'm not 100% sure though to be honest as it had been a long day by that time and I just wanted to get home and crack open a beer!
It seems that every time I drive my wife's car I find something is wrong with it and I just can't be bothered with it after a long
week's work. I'm sure you know what I mean. However....
<takes deep breath and sighs...>
...I'll look out the overalls tomorrow, and my wooly bonnet might be required too as it is very frosty, and I'll have a look underneath. I
need to change the oil anyway and I've got new springs for the rear and front ARB bushes to fit too. I had a go at the rear springs a while back
but couldn't get them out. I thought they would fall out when the shocker was detached but not a chance. I'll need to dismantle the lower
arm I think. The ARB bushes are going to be a ball-ache too as they are firmly attached to the ARB. I've got power flex replacements but I need
to get the old ones off first.
Thanks,
Craig.
MakeEverything
| posted on 14/1/12 at 12:50 AM |
Wheel bearing?
Kindest Regards,
Richard.
craig1410
| posted on 14/1/12 at 12:51 AM |
quote: Originally posted by MakeEverything
Wheel bearing?
Why would that change whether on or off power? Have you experienced this yourself?
Ninehigh
| posted on 14/1/12 at 12:57 AM |
Wheel nuts... It's a possibility
If it was the cv joints it would be worse when turning, and you'd have noticed it a long time ago (if it's that then it's a bad
case)
If it's some sort of mounting I'd imagine it would be more like one big bang when accelerating and one big bang when decelerating...
Madinventions
| posted on 14/1/12 at 01:02 AM |
I had a similar problem once which was due to a combination of a loose(ish) engine mount and excessive play in the track rod ends (both inners and
outers). it was nowhere near as bad as what you describe, but if it feels like you say it does then it should be really easy to spot once
you're underneath it!
View my band website:
http://www.shadowlight.org.uk
MakeEverything
| posted on 14/1/12 at 08:07 AM |
Wheel bearing?
Have you checked?
Yes, I did get a knocking noise on overrun on mine, not vibration though.
Either way, worth a quick check of the wheels I would think. Or you could just ignore it and I'll not contribute again.
[Edited on 14-1-12 by MakeEverything]
Kindest Regards,
Richard.
Russell
| posted on 14/1/12 at 09:21 AM |
Can't help you with saying what the cause is but maybe I can help you to eliminate some stuff...
I recently replaced an inner CV joint on my VW Polo due to wear. The symptoms were the exact reverse of those you describe i.e. excessive vibration
but only when accelerating and nice and smooth on the overrun.
Further to your comment above, dual mass flywheels were fitted to VW group vehicles starting in the 1990s so it's possible you have one.
Smaller petrol engines tended to have solid flywheels though. Again, my experience of a failed DMF is excessive vibration on acceleration, not on the
overrun.
Russ
I'm a bilingual illiterate. I can't read in two languages.
adithorp
| posted on 14/1/12 at 01:09 PM |
Gut reaction from your description (heard thousands of descriptions and traced cause over the years) would be a rear tyre out of shape. Experience
also tells me that it could be dozens of things.
Start with the simple stuff. Jack it up and check the tyres don't have any lumps/bumps on them and check for play in the steering and suspention
joints, then get the wheel balance checked.
http://jpsc.org.uk/forum/
owelly
| posted on 14/1/12 at 01:48 PM |
I'd be looking for loose ball joints, track rod ends and stuff that could cause the wheel assembly to wobble when not under load. Wheel bearing
is a possubility but if it was that bad, you'd notice excessive brake pedal travel.
http://www.ppcmag.co.uk
phelpsa
| posted on 14/1/12 at 02:01 PM |
Ball joint would be my guess. Fine when you load it up, wobbles around when unloaded.
craig1410
| posted on 14/1/12 at 02:47 PM |
Wheel bearing?
Have you checked?
Richard,
It sounds like I have somehow offended you or given you the impression that I don't value your contribution. Having read my reply again
I'm not quite sure how I managed it but if you are somehow offended then it was not my intention. Perhaps you misinterpreted my tone or
something.
I've not been out to look at the car yet but rest assured I will be checking everything suggested by everyone until I find the cause. My gut
feel is that it is an inner CV joint but there have been many suggestions made with good reasoning and I'll check each of them. That's why
I posted my question in the first place. I was hoping to hear from someone who had the exact same problem on an Altea or Golf or equivalent Audi but
I'm not that lucky it seems. It was a long shot...
Thanks to all who have posted, I'll let you know what I find.
Craig.
MakeEverything
| posted on 14/1/12 at 03:48 PM |
Wheel bearing?
Have you checked?
Richard,
something.
Craig.
Hi Craig, no not offended at all. Just a bit puzzled as to why you asked me what you did, and no-one else! I was adding to a growing list of things
that I would check. I've seen bearings do what you describe on large fans, the torque from slowing causes them to twist inside the play that
they have and judder when worn.
To be honest, it could be a multitude of things, or even a combination. I would start at e bearings, bushes, tyres etc and go from there.
Kindest Regards,
Richard.
craig1410
| posted on 14/1/12 at 04:30 PM |
Hi again,
Okay finally got around to having a quick look at the car and it looks to be engine/gearbox mount related.
If I open the bonnet and grab the engine and push and pull firmly there is a lot of movement, perhaps an inch or so and a sound coming from down near
the gearbox which could be a loose bolt moving around or it might be something broken or a rubber mount failed. I can't really see very well as
it is underneath the battery box and I don't want to start dismantling now without knowing what I'm likely to find. I've got the
SEAT workshop servicing software "Elsawin" so I'll have a look at that and see how the mountings are arranged. Then I can have a
proper look tomorrow once I know what I'm letting myself in for.
@Richard, no problem mate. I did actually respond to each and every post up to and including yours but it was starting to feel as if I was responding
a bit too quickly so I decided to back off until I was in a position to actually do something about it. Sorry if this gave you the wrong impression.
No hard feelings.
Thanks all,
Craig.
T66
| posted on 14/1/12 at 06:28 PM |
One of the rear wheels on my Saab lost all its weights
Up to 50 nothing to note, came on as a gentle thrum between 60 and 70. And was easily low enough to ignore.
By 70+ up to 90 it sounded like and engine undertray hanging down in the air stream under the car, and vibrated like a PIG !
Took it to HiQ and got them to balance the fronts, both were fine, when I told them to do the rears the fitter fell about laughing, pointed out he had
never needed to balance rears before.
Ate his words as the rear was missing 60g of balance weights. Once fitted, the vibe disappeared completely.
When running the car at speed it was very hard to tell what was going on, ie whether it was front or back, driving or overrun etc.
T66
| posted on 14/1/12 at 06:29 PM |
PS - Ignore my last post
craig1410
| posted on 15/1/12 at 05:25 PM |
Just a quick update.
I took the battery and battery support out today to get a good look at the engine mount and it does appear to be pretty knackered. It creaks when
moved and I can move it by finger pressure a bit too easily. I'm assuming that these mounts should be able to resist finger pressure without
moving much? I've never seen a new one before hence the question.
So unless anyone comes back and tells me that they are supposed to move easily by hand pressure then I shall order a new one (about £45 from a quick
check here http://www.hansautoparts.co.uk/1K0199555NMounting.aspx ) and fit it next weekend. It should be okay until then I think as my wife only
drives about 10 miles a day on local roads so vibration at speed isn't a big problem for her. To help it stay together I squirted a dose of glue
into the gap between rubber and metal. I doubt if it will help much really but might firm it up a tad.
Only problem I have now is that my airbag warning light has come on, presumably due to the battery being disconnected. I've got a VAG COM cable
but my daughter had the only Windows laptop we've got left and she's away from home at university. I think she's home in a couple of
weeks so hopefully I can reset the fault code then. I'm hoping that is all that is required - anyone seen this happen before?
On a positive note I got the oil and filter changed which is a bit overdue and completed a few other service items.
Craig.
