coyoteboy
| posted on 17/1/12 at 08:37 PM |
Exhaust valves. Not that sort
Anyone know of anywhere selling exhaust valves of the sort Aston etc use to clear their throats at high loads? Just curious really.
Ninehigh
| posted on 17/1/12 at 09:05 PM |
Que?
When you said "not that sort" it thought you weren't thinking of car exhausts.. Now you're telling me they have valves to help
you clear your throat? I've got Lockets on my mind now....
Brrrraaaaaaaaa!!!! *drops locket in petrol tank* Brmmmmmmmmmmm......
I'm really curious as to what an exhaust valve is now
paulf
| posted on 17/1/12 at 09:20 PM |
I think Rally design sell some exhaust diverter valves that are cable operated if that's the sort of thing you mean.
Paul
gregs
| posted on 17/1/12 at 09:38 PM |
Not 100% sure about AML, but ones I have seen on similar cars are vacuum activated bypass valves at the silencer end.
owelly
| posted on 17/1/12 at 09:57 PM |
I have a vacuum operated exhaust diverter valve if its any good to you? Seems to be a heavy bit of kit!
http://www.ppcmag.co.uk
NigeEss
| posted on 17/1/12 at 10:50 PM |
Do you mean something like the Yamaha EXUP (other manufacturers are available ) type thing ??
bi22le
| posted on 17/1/12 at 11:05 PM |
maybe you could use the boost control valve from a shot turbo. Been cut the whole plate out and weld onto the exhaust. you could use an actuator to
open it.
Please read my ring story:
matt_gsxr
| posted on 17/1/12 at 11:19 PM |
like one of these?
http://www.dmhperformance.com/
matt_gsxr
| posted on 17/1/12 at 11:21 PM |
Or these (if you are in the UK, I think you are still in the UK today!).
http://shop1.actinicexpress.co.uk/shops/Rat_Sport/index.php?cat=Exhaust_Cut_Out_Valves
They have a couple of options.
coyoteboy
| posted on 17/1/12 at 11:54 PM |
Wow, what a set of replies! Sorry, didn't realise the initial post was as confusing as it is - lack of coffee to blame there. But glad to see a
bunch of people got the idea! Cheers for the links, I'll go trudging around them for a while to see what I can see. I was considering an
optional "straight pipe" solution for fun times while keeping the car pleasant for long runs, but if it's got a massive weight
penalty fixed to it I'll deal with a fairly quiet car.
Ta again, knew I could trust the hive mind!
owelly
| posted on 18/1/12 at 01:03 PM |
The valve I have has a heavy vacuum unit on the side but if you binned that and just had a solenoid or cable operation, it would be doable. I'll
try to remember to take some piccies tomorrow.
