Author: Subject: Camber gauge
matty h
posted on 1/2/12 at 06:53 PM Reply With Quote
Camber gauge
Looking a getting o digital inclinometer to use as a camber gauge what do you think.
Digital Angle Gauge Protractor Inclinometer + Pouch NEW | eBay
Matty
[Edited on 1/2/12 by matty h]
ashg
posted on 1/2/12 at 07:14 PM Reply With Quote
i have got one works well stuck to a brake disc
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
matty h
posted on 1/2/12 at 07:30 PM Reply With Quote
Was thinking lenght of angline and two bolts at correct distance to put on the wheel rim.
posted on 1/2/12 at 08:46 PM Reply With Quote
Usual way with road cars was just to put a camber gauge against the tyre slightly offset from centre to avoid the bulge. on older cars with narrow wheels this also avoided the hub.
Yes this creates an error but as long as the tyres are pumped up to 40 psi it is less than -1/8 degree and the error will be consistent between measurements.
The most significant error to allow for is any slope on the floor used as a set pad.
Bluemoon
posted on 2/2/12 at 09:24 AM Reply With Quote
Have one, they are o.k, actually accurate to 0.1 degrees, tested against a rotating tool table, but mine is little sticky sometimes, (tap like you do on an old barometer all is then o.k.). I plan making a bar with two bolts allow measurements on the rim.. Really quite good for the cash, but don't expect it to work as well as an expensive one!
Dan
matty h
posted on 6/2/12 at 09:22 PM Reply With Quote
My new camber gauge.
eBay - The UK's Online Marketplace
Matty
