Author: Subject: Turbo
philw
posted on 8/2/12 at 05:38 PM Reply With Quote
Turbo
Guys, I have a plan which involves a using a Turbo which i am about to acquire origin/condition unknown, is there anyway of telling if the Turbo is knackered by a visual inspection/what do I need to look for?
Thanks in advance
Must try harder
MakeEverything
posted on 8/2/12 at 05:43 PM Reply With Quote
Play in the shaft primarily, and oil residue in the ports. The truth will come whn you run it.
Kindest Regards,
Richard.
PSpirine
posted on 8/2/12 at 05:49 PM Reply With Quote
A lot of turbos also can have cracked exhaust housings (look particularly between the internal wastegate port and the exhaust port), although these will often quite happily run for 50k like that - depends on the price whether it's worth it or not.
As mentioned, play in shaft - in/out as well as side to side. Expect a tiny bit with no oil pressure but anything more and it's worth doing a rebuild. These cost about £40-50 unless you've got some super fancy turbo.
When you eventually fit it and run the engine, if it's pumping out blue smoke when on boost, it needs a rebuild. If it's not boosting much at all, then check your pipework for leaks, and if it traces back to the turbo, chances are it's pretty knackered (but you should be able to tell this visually as there will be obvious damage to the turbines)
Bare
posted on 9/2/12 at 03:18 AM Reply With Quote
As above; NO palpable play in any direction on the compressor shaft AND it needs have a Water as well as oil feed.
Non watercooled turbos are worthless .
philw
posted on 10/2/12 at 04:48 PM Reply With Quote
Another question, on a turbo with an internal wastegate can you do away with/bypass it and use an external one?
Must try harder
tomgregory2000
posted on 10/2/12 at 05:00 PM Reply With Quote
yes you can weld up the wastegate and fit an external one onto the manifold, pre turbo
tomgregory2000
posted on 10/2/12 at 05:01 PM Reply With Quote
sort of like this link
beaver34
posted on 10/2/12 at 05:20 PM Reply With Quote
although there prone to crack and break the weld due to the heat from what people have said, im going to fit a bracket to hold the wastegate shut phycicaly on mine so it can be run on a internal wastegate too if i sold it.
philw
posted on 10/2/12 at 05:28 PM Reply With Quote
Can i not remove the actuator and replace that with a solid bar to hold it shut?
Must try harder
posted on 10/2/12 at 05:34 PM Reply With Quote
A plain bearing turbo will always have some play in the radial direction, even when brand new. This should be fairly small however, and certainly not enough to allow the compressor to touch the housing. There should be virtually no axial play.
