macc man
| posted on 8/3/12 at 03:17 PM |
MX5 tickover
Having problems with a high tickover during warm up on my wifes MX5. It revs at 1700 rpm even when up to temp. It finaly goes back down after about 3
miles. I tried cleaning the plenum chamber with carb cleaner but made no difference. It may be a temp sensor faulty but cannot find it on engine. Any
help would be appreciated.
ChrisL
| posted on 8/3/12 at 03:32 PM |
there's a way of reading the fault code via the ODB2 connector, depending on year, have a look on miata.net
BigLee
| posted on 8/3/12 at 05:20 PM |
The temp sensor is at the back of the engine below the coil pack. If its a UK car it'll be a green clip, if it's an import, it'll be
grey. There are actually 2 sensors in that location. One for the ecu on the top (screws in vertically) and one for the gauges below it (screws in
horizontally).
You'll need to remove the coil pack 1st with the 2x 12mm bolts holding it to the cam cover, plus another 12mm underneath into the head.
Lee
lsdweb
| posted on 8/3/12 at 06:19 PM |
Fault code diagnosis - here
macc man
| posted on 8/3/12 at 07:11 PM |
Thanks for the replies and advice. I will remove the coil pack and have a look. Henry.
| posted on 8/3/12 at 08:59 PM |
I had the same problem with the Kia and it was the throttle position sensor potentiometer shot.
