Author: Subject: Renault Master Van Oil light coming on
madrallysport
posted on 20/4/12 at 10:36 AM Reply With Quote
Guys, my 2004 Renault master van has a falut, i've googled it and cant find anything about it, just hoping someone on here can shed a bit of light on it for me.
The van has oil in it ok (according to dipstick), it starts and runs fine, when i turn it on, all warning lights come on and off when it starts as normal, also message is displayed saying oil ok, but when i rev the van to 3000 rpm (when driving or stopped) the red oil warning light comes on and the stop light. The engine doesn't have any strange sounds coming from it, but then i havent ran it very long due to this as i'm scared it'll get damaged.
Has anyone seen or heard of this fault before or can possible help me.
Davy
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
westf27
posted on 20/4/12 at 10:55 AM Reply With Quote
not come across that fault.Would suggest an oil flush,new oil and filter.If the engine has a high mileage maybe the strainer is partially blocked.If so then hopefully a flush will clear it.
555
posted on 20/4/12 at 11:20 AM Reply With Quote
Oil pressure maybe warning?
As above, an oil and filter change could be worth a try.
What's the mileage and history like?
theconrodkid
posted on 20/4/12 at 06:47 PM Reply With Quote
if it comes on at 3000 revs then maybe vibration at those revs is causing the oil pressure switch wiring to earth out?try driving below 3000
who cares who wins
pass the pork pies
