morcus
| posted on 18/5/12 at 01:05 PM |
Is it safe to charge a battery on the patio?
Can I charge a battery in my Garden? I've got no power in the garage and I can't park close enough to the house. Obviously I'd only
charge it up when it was dry but is it safe and should I take any other precautions. From what I've read I'd rather not risk doing it in
the house.
A1
| posted on 18/5/12 at 01:12 PM |
ive charged plenty of batteries in the house... should be okay to do it in the garden, just put a bucket over the charger to keep it dry...
PSpirine
| posted on 18/5/12 at 01:17 PM |
Absolutely fine just make sure your mains lead is safely covered and away from water (or better yet have a water/splashproof extension), and cover the
charger and battery from rain.
I've charged batteries by putting an extension and charger under the engine bay (closed bonnet) overnight many times, and they've never
got damp.
I do always plug everything in and only then turn on the socket! Similarly, switch off at the socket before touching anything when you're done
charging, just in case.
| posted on 18/5/12 at 01:29 PM |
Yes, no problems. I'd just stick a bit of hardboard or something over it to keep the rain off the charger but that's about it
James
| posted on 18/5/12 at 01:43 PM |
Many years ago my father charged a battery that gave off some hydrogen while doing it. When he took off the croc clip it sparked and the battery
exploded showering him in acid.
He ran straight inside and held his head under the tap to wash out his eyes etc and he got away with it. But it burnt holes in his shirt in the
process!
So, as suggested, turn off at wall first so as to minimise sparks.
I suspect charging it outside is safer as the breeze will blow away the hydrogen and help prevent what happened to my Father.
James
- Muhammad Ali
Bluemoon
| posted on 18/5/12 at 02:26 PM |
process!
James
Eck must remember to be careful, I know that's what I should do but.. I think this is about the first time I have heard someone actually manage
that, the hydrogen normally manages to escape quite well!
| posted on 18/5/12 at 02:31 PM |
Make sure its in a safe place avoiding the obvious trip hazard...
Slimy38
| posted on 18/5/12 at 02:34 PM |
Amen to that. I'd once ran a battery charger to under my car bonnet, hooked it up and left the extension lead going from the car to the garage.
The paperboy seemed a little shocked to find his legs were no longer underneath him and his papers no longer in his bag...
hughpinder
| posted on 18/5/12 at 03:32 PM |
I managed to explode a battery on my tractor while charging it outside on a windless day- spark ignited the hydrogen. since it was basically at face
level and about 12 inches away it seemed quite a powerful explosion. Luckily there was a hose on the wall directly behind me and I hosed myself down
pretty quick - still got a a scar on the back of the hosing hand where I missed a bit. I found one of the caps from the battery cells about 50 ft way
and bits of the plastic battery casing all over the place!
So just remember to switch off at the wall first...
Hugh
Canada EH!
| posted on 18/5/12 at 04:11 PM |
Once and again, do not cover a battery while charging the hydrogen gas it gives of is very explosive. That is why all motorcyle batteries have vent
tubes leading to the bottom of the bike.
coyoteboy
| posted on 18/5/12 at 04:53 PM |
I know of a chap who knew a chap who left a battery on charge on a garage workbench, at some point a spanner fell across the terminals while they
were out (washing machine under counter maybe?). They came back to find the back half of the garage in rubble form.
Batteries carry a lot of energy
| posted on 18/5/12 at 05:18 PM |
Please don't put a bucket over as it is a potential bomb, you can over it cover but you must allow lots of ventilation.
Don't over charge and charge at a low rate to avoid producing lots of hydrogen gas.
Switch the charger off (I always do this from the mains socket) and allow a few minutes for gas to disperse before taking the crocodile clips
off.
[Edited on 18/5/12 by britishtrident]
SteveWalker
| posted on 18/5/12 at 05:29 PM |
He only said to put the bucket over the charger, not the battery - presumably in case it rains while the charger is plugged in.
morcus
| posted on 18/5/12 at 05:31 PM |
Thanks for the tips. You seem to be saying that if I follow all the usual rules and instructions and do it when it's not raining it should be
fine. I went to look for chargers and read everything I could find online and I might not bother and just get myself a new battery for the moment, or
wait till I'm free to spend all day at my grandads or uncles and borrow their leccy.
On a side note, with the negative terminal not connected, nothing can draw power can it?
D Beddows
| posted on 18/5/12 at 05:47 PM |
Good lord, don't ever drive the car - that's REALLY dangerous.......! Whatever happened to common sense? don't charge it up outside
when it's raining or use a pressure washer to clean it while it's charging etc etc otherwise just do it - absolutely everything is
dangerous beyond belief if you consult the internet
T66
| posted on 18/5/12 at 05:56 PM |
When I worked on trucks in the 80s - we had a balls out charger for zapping truck batteries with plenty of amps, only problem was the timer was
broken. So we always switched it off before we went home.
Until we forgot to switch it off on Friday,leaving it on all weekend.
It was on 90 minute quick charge, and it had been on all weekend. Anyway it didnt catch fire, but the whole garage stunk of eggy farts till lunchtime
monday.
The haulier got a new battery on the company.
MakeEverything
| posted on 18/5/12 at 07:21 PM |
We've had a spate of exploding generator batteries lately. I wouldn't charge one in the house in future, or near anyone.
Kindest Regards,
Richard.
| posted on 18/5/12 at 07:59 PM |
There's a start and charge round at the bike shop and you turn the switch to give it a boost and it returns on a spring to the maximum level. If
you wedge it with an Allen key and forget it makes batteries change shape and steam comes out of the vent.
mangogrooveworkshop
| posted on 19/5/12 at 07:26 AM |
Tell me about it Ive seen a load of UPS batteries swelled up to mega size ready to blow......we take the juice off them and come back later
adithorp
| posted on 19/5/12 at 09:09 AM |
off.
Many moons ago, when batteries were a lot poorer quality than they are today and gassed a lot more... I was taught to always to blow over the top of a
battery, before connecting/disconnecting anything, to disperse any gas.
Morcus, yes you are correct, once the neg' is disconnected nothing can draw power. Always disconnect neg' from the battery first. That
way if your spanner accidently touches chassis/engine/earth while doing it, nothing happens. Then when you disconnect the positive, thats also safe if
your tool touches body/engine etc.
http://jpsc.org.uk/forum/
coyoteboy
| posted on 21/5/12 at 12:32 PM |
quote: Good lord, don't ever drive the car - that's REALLY dangerous.......! Whatever happened to common sense? don't charge it up
outside when it's raining or use a pressure washer to clean it while it's charging etc etc otherwise just do it - absolutely everything is
You wouldn't believe the number of people lacking common sense these days. No-one said don't do it, just warned him to bucket the charger
and then relayed a bunch of funny tales.
[Edited on 21/5/12 by coyoteboy]
D Beddows
| posted on 21/5/12 at 01:31 PM |
No, I appreciate that but all the scare stories then prompted him to say that he was just going to buy a new battery instead! Yes of course
batteries can be dangerous if you're a muppet or very unlucky but there are statistically far more dangerous things you can do.......like drive
a car as I mentioned!
[Edited on 21/5/12 by D Beddows]
coyoteboy
| posted on 21/5/12 at 02:16 PM |
Probably more risk in driving to get the new battery
morcus
| posted on 22/5/12 at 02:43 AM |
TBH it was more the costs and mucking around that put me off. A battery charger is still on my shopping list but my car will need a new battery
eventually (As the current one is the wrong size and tied in with phone cable, and wedged in by the spare wheel) so I might aswell fix that at the
same time as changing the alternater rather than end up doing two jobs.
I'm not planning on driving this car all that much (as I don't commute now) so I'll probably be charging batteries on my patio soon
enough.
On a side note, any one intrested in a battery? I'll have a look and see what size ect when I swap it out, it's flat now but it got me
from Brighton to Clacket lane so it probably still works.
